I searched through almost every thread with no solid answers. Mainly I need to know the 2 wire colors to the stock fan, the resistance values of the sensor in the radiator and the sensor resistance value for the sensor at the top of t-stat housing. The previous owner swapped in a talon 6bolt so things may be a tad different.
Im running a slimline fan and its always on when the ignition is on, so is the A/C fan. The slimline is wired; blue to blue, black to black? thats how it came is that correct? The single wire sensor on the back of the Tstat housing is hooked up and my logger shows proper temp, and the dash reads proper temp. Here are a couple pics.
The sensor on top in the pic has no resistance value at any temp, what is spec ohm at operating temp? the sensor on the radiator reads OL no matter what temp.
Also what does the white plug goto in the 2nd pic?
