Fan wiring trouble.
EgonOlsen
Denmark, Europe.
Today I went to fit the Condenser on the car+ the fan for it but I noticed that my radiator fan plug goes all the way to the driverside and plug into what I think is the condenser fan plug.
I tried to find a similar plug on the passengerside for the radiator fan but could not. I did find 2 loose wires that seems to be for a fan.
I idea was to take away the white plug that has no function and the black ones and just take the 2 wires from the fan and connect them to the 2 loose wires as seen marked 1 on the pictures.
Is that the correct wiring?
Where the radiatorplug is now
Thermosensor and fan wiring
Harness plug passengerside
dammitjim
WI
This is similar to a problem I've got here - click
The white plug looks like the one that goes to the temp switch below the fan.
The blue and black wires may be the ones that go to the fan motor.
EgonOlsen
Denmark, Europe.
I think my white plug is a spare, since I already have a plug on the sensor.
Maybe I have 1½ harness? or maybe the Fan comes from another car with a slightly different setup?
The fan atm is not connected at all to the wiring at the passengerside. it has its own wire with the white plug and a 4 connector plug which is atm. plugged into what I believe is the condenserfan plug.
The passengerside wiring go from harness, to sensor and resistorpack and nothing else, then have the 2 loose wires.
So my plan was to cut the wire on the fan off(the white plug and 4 connector plug) and solder it with the 2 loose wires as I think they should have been.
That is actually my question, if thats the right thing to do. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Maybe this make more sense.
dammitjim
WI
This is how it should look on a US car:
