bcjjones
I searched and found nothing about this question at all. I found ignition timing but not mechanic.
With running an evo 8 ecu, shouldn't the mechanical timing be switch with the ignition timing? As in the timing should be set with the number four cylinder at TDC instead of the number one? Since the number four cylinder is now the number one with the evo 8 ecu?
