Down pipe options
bmxkid415
Bradenton FL
My down pipe and "cat" have finally fell apart. Was heading up to Orlando FL and as soon as I took the on ramp from
I 75 to I 4 the car got loud. I knew something was up, I pulled over and saw the cat had broken off at the flang to the cat back. Needless to say a quick auto parts search on the GPS came in handy. Was able to get a small section of pipe and used exhaust putty. I wasn't turning back, Just filled the tank and the Cherokee gets horrible gas mileage.
The down pipe is a 3inch to a cat then a 2.5 stainless steel cat back with a magnaflow muffler on it. I know I can either use a 1G down pipe with a cat or a 2G one. Just seeing what others have done in the past and plan on doing. Not looking to break the bank, just want something that will or can bolt right up with out much hassels
Thanks for any help
Cory
AnotherNewb
Orlando, FL
The general set up is a 2g downpipe and a 1g cat back. You should check out tunersnation since the have vr4 specific set ups.
BluFalcon
Wichita, KS
I'm using a Road Race Engineering EV03 downpipe for a 1G AWD on my car. Fits perfectly, with no issues and it's decently priced. The downpipe goes 2.5 inches off the O2 housing and then goes to 3 inches after the flex section. I have a cat with flanges, so that the cat can be removed if needed. Like you know...at the track. /ubbthreads/images/graemlins/devil.gif
just did 2g downpipe (ebay obx) and made an exhaust. here is a gvr4/1g awd exhaust difference pic i just took
vr4 on right
Nartanian
Richfield, MN
Nice comparison. The DPs look interchangable /ubbthreads/images/graemlins/dunno.gif
bmxkid415
Bradenton FL
Looks like the cat itself is just longer on the VR4. Interesting. As for Emissions, I can care less. The cat that was on the car was just a shell.
Anyone have pictures of a 2G down pipe set up?
NickDromez
Berkeley, CA
i have an ebay 2g dp. it sorta fit. i got it done at an exhaust shop, and they had to bend it a little at the top so they could bolt it on easier. it also comes very close to the oil pan (idk if thats a concern of yours). also since its a cheap dp i had them cut it up so i could fit my "all flow 3'' cat". i have it connected to a 2.5" Thrush glass pack. and a black flowmaster muffler at the end. sounds great in my opinon, quiet at idle, loud at WOT.
bmxkid415
Bradenton FL
I would like something that would just some what bolt up with out much needed cutting or hacking. An option I was thinking was doing the 1G down pipe then have one of the guys in the body shop weld up a test pipe. I just need to get some flanges. I am going to head to work early tomorrow and at least get this clamp tight with my impact so I can at the very least drive the car the 2 miles from the shop and home with out it sounding like a dump truck
Just need to see what metal the guys can weld then go from there.
Thanks for the info!
raptorWagon
Oak Harbor, WA
Megan racing has a 2G downpipe that could work, eliminates the cat, then just fab on the rest from there. If mine wasn't s one piece setup I'd send it to you.
