Long story short I have a low clutch pedal. M/C and S/C are both new, OEM replacements, I have no pedal assembly issues (per jack's transmissions test method), flex line in hydraulics is an RRE braided line, clutch is a ACT 2600 w/ 6 puck, flywheel is RRE "no-name", clutch fork is less than 5K old. Jack's performed the M/C push rod adjustment.
All of that and still a low pedal. Somewhere here I read that there is a S/C that is bolt on that has a smaller piston (3/4" vs 13/16") than the factory S/C. After some research, I found that NAPA sells a version with the small piston, P/N 37918. I'm going to install this today, I'll let every one know.
