desant78
Hello gvr4.org
I can't seem to rev past 6k, under load or just dragging out the gear. This happened before I took the car apart, and is happening now.
I have a keydriver stage 3 chip, but will post the specs of the CHIP once I found the paper work for it, and confirm it is in the car.
My log shows 0 knock, and seems to be heatlhy. This really feels like a fuel cut. I have no wideband installed yet (PO drove the car for year without it, so I drove it during the break in of the flywheel and clutch).
I have a e3 16g, 560 inj, 3g MAF. Car idles fine, pulls great, and boost to 10 psi (spring) until about 5k where it spikes to 18. BISS, TPS, and base timing all set per manual and vfaq. I have a fuel lab FPR set to 37.5 psi without vac. During the break in, I never revved past 4k. since I'm past the break in, I tried just to run out the gear, and the fuel cut came back. I will install a wideband and new fuel pump, hopefully this weekend but really would like to get some opinions on where to look.
I don't really boost or rev high right now, because I don't have my wideband installed, but I am trying to get a head start on the research.
Any suggestions, opinions, or info I need to find would be greatly appreciated. I will post the keydriver info tonight or tomorrow.
thanks in advance for the help!
