manikbastrd
- Joined
- Nov 19, 2009
- Messages
- 660
The build is for a replacement bottom end for my car. I have a local machine shop who will do all the machine work, and do ring gaps. He is actually a buddy of mine so he will probably oversee me assembling the block itself (not my first but I am not super confident). Build is for a bottom end that will handle up to 700HP. I am only really shooting for 500-600 AWHP (gotta be able to beat my buddies evoX with 540AWHP), but want to have it good to go, and not have to worry about anything (I have not decided on a turbo yet, but I do have a head built). I thought about going stroker or destroker but can't come up with a great reason to do either. List is as follows, please chime in if you see something bad or that I should reconsider...
Stuff I need stilledited)
Good core for bottom end w/Crank
Mahle Powerpak 9.0:1
Carillo Rods
ARP Main studs
Clevite 77 main and rod bearings
New Mitsu oil pump case and gears
New mitsu water pump
Balance shaft delete kit
Fluidampr harmonic balancer
Haven't decided on HG yet...Thinking Mitsu MLS or Cometic
Things I have:
ARP Head studs
New Mitsu timing components
Stock Timing belt
7bolt head bored for 6 bolt studs
-1mm overbored valves
-ported all the way around
-HKS 272/272
-New Topline revised lifters
-Manley Springs and retainers
JMF intake manifold
Stock 1g TB
FP exhaust manifold
Turbo and o2 housing TBD
Thanks in advance! /ubbthreads/images/graemlins/worthy.gif
-Manik
Carillo Rods
ARP Main studs
Things I have:
ARP Head studs
Stock Timing belt
-HKS 272/272
JMF intake manifold
Stock 1g TB
FP exhaust manifold
-Manik
