Build Thread of 385/2000
Vr4junkie
Some wack town in CA
Thanks guys little by little its getting done now I need to by a soda blaster or media blaster.
CutlassJim heres the link >> click
Vr4junkie
Here's a little update... some new parts that have been laying around now that im currently unemployed Ill be working on the car a lot more /ubbthreads/images/graemlins/rofl.gif but tomorrow I should have the suspension parts back from soda blasting and ready to paint.
Heres a few pics for the meantime.
New Tie Rods
New Wheel bearings all around
New Ball Joints
New Wheel Bearing seals
New boots
Vr4junkie
Couple parts back from soda blasting should start painting by tomorrow.
G
zompton
Looking good.
LIV4PSI
O-H-I-O
Great job so far. I have been taking on this same project on 1501, so I understand just how much work is involved. Hopefully you didn't have to fight as much rust as I did
mitsuturbo
Near Seattle, Washington
Quoting Vr4junkie:
5lb Tumbler works awesome defiantly recommend one of these.
And what or who exactly is it you are defying by recommending one of these?
Vr4junkie
Rust wasn't really an issue I think the only thing that really had any rust was the rotors /ubbthreads/images/graemlins/rofl.gif
The tumbler is a nice tool to have around I mostly use it to clean bolts and small parts leaves the threads nice and clean and there cheap if you use there 25% off coupon.
So here's a little of today's progress.
pot
Fayetteville, NC
Quoting mitsuturbo:
Quoting Vr4junkie:
I was slightly confused myself. Of caution though, while the tumbler is great for small pieces like the water neck, caliber bracket, etc, be cautious with the bolts as the medium will remove the factory zinc/cadmium coating. This will cause your bolts (while looking sharp in the short-term) to wind up acquiring surface rust.
Vr4junkie
Sprayed a last coat of anti corrosion paint
Almost assembled missing a few bolts
Jay Racing rear toe elimiinator and rear upper adjustable control arms
Evo suspension on Swift springs.
G
zompton
What's the part number for the sankei ends?
Vr4junkie
This is it G got them off Amazon.
G
zompton
Sweet, so sankei # se-7261. You know these are for a space wagon right? Edit, I see the new # mb564991 works for galants.
Vr4junkie
A little update front and rear bolted up might finally touch touch the floor again.
Vr4junkie
She's finally off the jack stands .
Vr4junkie
Yes it was all that hard work finally paid off but yea it did felt great knowing its got fresh new bearing and literally all new bushings /ubbthreads/images/graemlins/smile.gif . But it's still has a lot to go but its getting there little by little.
Vr4junkie
Getting the engine bay ready for some paint.
Vr4junkie
Just got done painting the engine bay it's a metallic grey can't really tell by the crappy phone pictures not the best painting by far but might keep it for a while.
