Bolt size question
Diego
About to finish up the few last things, and I need these bolts..
What is the size for the bolts (4 total) on the turbo drain line. From the turbo side to the Oil pan side.. .I need these, if one of you part junkies have these, let me know and I will shoot you some Paypal for them pronto.
Diego
They are 6 x 1.0 mm. About 20 mm long does it.
fuel
Toronto, ON, Canada
with a 10mm head.
All proper 6 mm bolts should have a 10 mm head, JIS or ISO.
89Mirageman
Stantonsburg, NC
Also the two for the oil pan use a special sealing washer. I would just grab them from the dealer, they're not that much.
Diego
John (TB) mentioned that, I'm going to cut by, by using a copper washer behind the bolt
Diego
Not finding anything within size local
Someone want to be a pal and let me know the P# for them since it looks like I need to order them instead of hunting for these little guys.
Diego
Galantvr4559
Denver, CO
I should have what u need but u r in greeley and im in denver. Maybe this weekend I can take a cruise up there to drop off some right bolts to u.
Diego
I bought some new off JNZ, caved and found a few other things I could use... Come up this weekend if you can... maybe go for a cruise if we finish early enough....
