Autozone slave cylinder ok?
1badgvr4
georgia
Just wondering if I should wait to get an oem one but the zone one has a life time replacement.or should I just rebuild it?
Andy_S
Shithole Wisconsin
I had an autozone one. Worked fine for the time I had the car. It was a stock clutch so I am not sure if a heavy clutch would make a difference.
boostx
Orlando, FL
Just make sure you get the Galant 2.0 turbo one.. I made three trips to the store before i got the right one.
mikus
Aurora IL
I've bought one before and will not again.
It may work fine but I'd ask myself, is it worth $20 more to make sure I have the right part 1st time, and to only do the job once?
atc250r
Orange County, NY
1G DSM slave is the same and works fine. I have an AZ one in my car for about 20K now. I forget which years to order for the big vs. small piston. Big piston = lighter pedal but less travel at the fork. Small piston = heavier pedal but more travel at the fork (theoretically less chance of grinding on shifts).
John
1badgvr4
georgia
Ok got a slave for the car, but how do I bleed it now that I have no pressure in the system.If I pull the pedal up then open the valve and pull back up on the pedal then it will just suck air in.
small jar
small hose (preferably clear) that fits snug on the bleed screw
new bottle of DOT 4 brake fluid
Fill the master resevior. Fill the little jar about half. Put hose on bleed screw and other end submerged in jar of fluid. Pump clutch pedal several times. Refill master. Pump several more times. Crack open the bleeder ever so slightly and leave it that way. Pump pedal several times. Close bleed screw. You will probably notice air bubbles in the jar. The air was forced out and clean brake fluid was sucked into the cylinder in its place. Repeat this a few times and your clutch pedal should be bled perfectly.
1badgvr4
georgia
Well I was by myself so what I did was get a long bar pushed the clutch down and got the bar cought on the seat and cracked the valve open.I pulled this own slave off another one of my cars and when I did alittle spring popped out from under the boot.I left it out and everythig works, and now I can get into first gear but of still grinds if you try to shift with some quickness
Usually if you push the clutch pedal all the way down with the bleeder open, the pedal will stay at the floor. Close the valve, pull the pedal back up and repeat.
