I'll start from the beginning. I traded a Lexus Sc300 for what I was told was a galant gsx with a vr4 swap. Well I'm no dsm wiz so I assumed it was. Even when looking at the engine I couldn't tell it was a non turbo motor. Anyways I made the trade. Car ran pretty good minus a slight boost leak at the J-pipe, the gas pedal had a ton of play and some rattling near the timing cover. Got the car home and drove it for 2 months until the timing jumped and well you know what happened. Had a local shop do the timing, fix the head and figure out why the pedal had so much play. Thats when I was told it was an n/a motor. Thats when it all made sense. The guy I got it from rigged the throttle cable so that I could never reach WOT. Now that the timing was fixed, and the head was repaired and the throttle cable was properly adjusted it ran like sh*t. Of course I was pissed. Drove the car from kentucky to northern michigan and parked it. Bought a cheap vw and drove it home. Car has been sitting up north since april. I'm looking at towing the car home around xmas time but I have some questions.
1. Does the Galant GSX have a 6 bolt motor and 4 bolt rear end?
2. Are the transmissions different?
3. Can I use my fresh non turbo head on a turbo block?
4. Can I just swap out the injectors and ecu? I already have fresh 450's to do so.
Sorry for the long post.
Pics of car:
Pics of car:
