801/2k Restomod
My idealized version of a Galant VR4
Drew84
Peabody, Ma
Un-insulated 16-14 gauge butt connector, They can be crimped only or in my case I crimped them and then soldered the ends, I didn't want them ever working loose. I got them from NAPA. I don't have the part # handy.
Drew84
Peabody, Ma
Yeah I've spent about 20 hours simply putting it back to stock and that's on the harness only.
you gotta sexy Tsi in that back there buddy =)
She's soo beautiful man, Im a sucker for Champagne 1ga's /ubbthreads/images/graemlins/grin.gif your not gonna paint it a different color or anything are you? Im also needing coilovers aswell
ApexHunter
Marysville, WA
Nice work on the gvr4. That cafe racer honda in your flickr album is awesome.
Leon_R
Chelmsford, MA
This is way too clean too be an original New England car, any idea where it came from?
dammitjim
WI
^^ According to carfax mine has been a midwest (WI/MN) car its entire life and looks more or less the same. No serious rust, many bolts/brackets/etc have surface rust.
Drew84
Peabody, Ma
Quoting ApexHunter:
The Cafe is my best friends, I can't take credit for that, just the photos. Leon which car? The Talon or Galant? The Talon has some minor surface rust and some very small rot near the door switches, but other than that is very clean. I've owned it for 10 years, so since 2004 it has not been driven in winter.
Leon_R
Chelmsford, MA
I was referring to the GVR4 /ubbthreads/images/graemlins/wink.gif
Drew84
Peabody, Ma
According to the Mitsubishi Super screen The GVR4 was sold in NH, but the customer apparently lived in AZ, till the car moved to Conn where I bought it.
Leon_R
Chelmsford, MA
Sweet! My Summit also spent most of its life in AZ!!!
BadVr4
manchester, ct
car was in CT for at least the past 12 years as far as i know. It was garaged the entire time and hardly driven. I used it only as a drag/street car and it was never a daily driver. Its probably one of the cleanest ones left in New England. Glad to see someone is taking care of it and bringing it back to being road worthy. I may still have some stock parts kicking around, like a/c stuff if you need it.
Drew84
Peabody, Ma
Installed the Trans last week, and slave cylinder.
IMG_0922 by Drew84(PASCARPHOTO), on Flickr
IMG_0932 by Drew84(PASCARPHOTO), on Flickr
Test fitted the JDM RS intercooler, I had to order some silicone hoses to make it fit, I'll have more on that later.
IMG_0931 by Drew84(PASCARPHOTO), on Flickr
Intermediate shaft installed, starter installed.
IMG_0933 by Drew84(PASCARPHOTO), on Flickr
While putting the axles in, I noticed the ball joints are junk, I'll have to change the lower control arms over. The tie rods don't look so hot either and the strut bump stop fell out in my hand. The front end will need some work before the car goes out on the road.
IMG_0934 by Drew84(PASCARPHOTO), on Flickr
I don't have the original air can so I took the one from my parts car and started to modify it to fit.
IMG_0935 by Drew84(PASCARPHOTO), on Flickr
IMG_0936 by Drew84(PASCARPHOTO), on Flickr
Cut the can up, sand blasted it a bit and my Dad fabbed up some brackets. Almost finished with it.
IMG_0941 by Drew84(PASCARPHOTO), on Flickr
We removed the sending unit because I had a feeling there was no pump in it. The car had an external set up...
IMG_0937 by Drew84(PASCARPHOTO), on Flickr
This is the cleanest sending unit I've ever seen
IMG_0939 by Drew84(PASCARPHOTO), on Flickr
IMG_0940 by Drew84(PASCARPHOTO), on Flickr
Except the feed line was welded closed
IMG_0938 by Drew84(PASCARPHOTO), on Flickr
So I have to figure out what to do with that. Some other issues that I ran into is the transfer case out of the parts car; even thought it looked nice. Had two failed bearings. When we went to change the output seal the oil that came out was thick with metal shavings. So I'll rebuild that one, because the t-case that came with the Galant has a bad input shaft bearing, but ok enough to put on the car and move it in the driveway. The car is coming along, I'll have the CM exhaust in this week, hopefully I can get it started soon.
Drew84
Peabody, Ma
I got the exhaust Tuesday from CM Performance. I'm a little bummed that the dual outlet system is a Y pipe not dual tips. But as far as fitment goes its really nice. Since I'm not a fan of polished exhausts I painted with heat paint yesterday in the morning while the turkey was cooking.
IMG_0942 by Drew84(PASCARPHOTO), on Flickr
Not a fan of this either, I will sand and polish this off.
IMG_0943 by Drew84(PASCARPHOTO), on Flickr
IMG_0944 by Drew84(PASCARPHOTO), on Flickr
IMG_0945 by Drew84(PASCARPHOTO), on Flickr
All painted up
IMG_0946 by Drew84(PASCARPHOTO), on Flickr
Much better looking
IMG_0948 by Drew84(PASCARPHOTO), on Flickr
IncorpoRatedX
Arizona
Very nice looking! Lets see some installed pics.
bobdole
U.K.
Is that the 2.5" system? You have to get the 3" inch system to get the dual tips. Mine is 3". I like how you painted the muffler black. I did the samething. Clean look.
Drew84
Peabody, Ma
Yeah that's the 2.5, I'm not worried, the black paint made it look a lot nicer. I like you car a lot by the way.
