5200 RPM luanch vs stock tranny
Vman911
Douglas county, Ga
Well I stripped 1st gear out at showdown yesterday.
Dropped clutch at 5200 RPM and 20lbs of boost.
Stock tranny didn't like it. Shot a tooth out of caseing.
4thStroke
Vancouver, WA
Stock GVR4 first gear?
Did it break right as you launched or did you manage to get going and it let go?
What kind of tires?
I ripped 3rd apart a while back, it's a pretty shitty feeling. Luckily I didn't break the case and paint the track.
Vman911
Douglas county, Ga
I believe it was stock 1st gear. Just put it in last week from a buddie of mine in tenn. I was running a 90 in there for last 2 yrs.
Fusion HRI tires at 24 psi.
When I dumped clutch I had some wheel hop let out of gas for a split sec hammered it down shifted into 2nd which didn't feel right, let off of gas down the track and could hear the teeth rattling around. By the time I got back to trailer there was fluid coming out a hole from a tooh that wanted freedom from the case.
IncorpoRatedX
Arizona
5200 rpms is nothing major, but 20psi is a killer. thread title needs to be changed to reflect that lol. I came in here thinking "i usually launch at 5500, whats teh deal?"
4Grim
Orlando FL
Yeah...5200 rpms and dropping the clutch on 1st isn't much of a issue, but at 20psi /ubbthreads/images/graemlins/ooo.gif
belize1334
Bozeman, MT
I always figured that you just can't dump the clutch on a DSM transmission. Ease it out of the hole and then let her rip!
Barnes
Richland, WA
The DSM 1st gear holds up a lot better right?
blackvr4
NJ
is it really necessary to launch at 20psi? I launch at about 10psi and i feel like that WAY more than enough.
deez
Chico, CA
Try the evo first gear next time. Its in mine, and although I am not hard on the car, I heard it holds up much better so I went with it.
