4WS pros . cons
Olson
Moreno Valley CA
Im torn between takeing the 4ws out or leaving it in. I'm putting a 3 bolt lsd in either one.
What I'm needing is the pros and cons and the handling characteristics with it intact disconnected or removed.
Remember this is from a road-race/auto-x prospective
H05TYL
Wgtn, NZ
cons = 3-bolt mech lsd has no drivegear for the 4ws pump. 3-bolt viscous lsd does, but is inferior.
Olson
Moreno Valley CA
I have a whole 3 bolt pumpkin
Muskrat
Lexington, KY
I've never expirienced it, but everyone who auto-crosses or does a track day with the 4ws intack has reported some pretty interesting effects durring high speed cornering.
Remember, the 4WS was intended for highway lane change assist. It actually increases turning radius. If you're wanting this as an auto-cross/road race car I'd ditch it. Less weight back there too.
H05TYL
Wgtn, NZ
Quoting Olson:
If you want to use a mech lsd it doesn't matter, whether you use a 3-bolt mech lsd, a 4-bolt mech lsd, or an evo lsd in the vr4 pumpkin, none of them have room for the gear to drive the 4ws pump.
This is a 3-bolt mech lsd from an early JDM vr4 RS
Olson
Moreno Valley CA
I understand the weight thing.
I've done one track day but i really didnt push the car as hard as i could have. more of a learning exp.
Olson
Moreno Valley CA
H05TYL - intresting... did the jdm vr4 rs have the 4ws?
gmtgmt - i know im kinda repeating myself here but. did the old rally vr4's have lsd's. Im sure they did but what setup did they use.
1qkfwd
Sun Valley, NV
From a racing standpoint I don't see any pros of keeping it. There's the weight factor, our cars are more predictable on how they corner with the rear solid. But if you ditch the 4ws you would have to rid of the active toe bushings with an elim kit.
Drive it with, disconnect the tie rod ends and tie them out of the way, then compare. See what you think.
misterfixit
Midlands, UK
Quoting Olson:
group 'n' had mitsu driveline.
group 'a' had full x-trac setup where the transmission, transferbox and rear pumpkin were completely different.
Rich
H05TYL
Wgtn, NZ
Early Group A cars used a locked centre diff (more likely a spool than a welded stocker, lol) and later they used a viscous coupling (again unlikely to be a stocker) - There's also a reference in the homologation papers to a 'centre diff control unit' - page 173 mentions Hydraulic control of centre differential.
On page 119 there is a 'H/Duty rear steering cylinder'
JDM vr4 rs, afaik they were only sold in Japan so the 'jdm' bit is redundant, anyway, they were available with 4ws and a viscous rear diff but are much more common with 2ws and mech lsd.
Olson
Moreno Valley CA
Well im going to keep the 4ws and spend the next 3yrs lookin around japan for a diff
fuel
Toronto, ON, Canada
do any of the USDM GVR-4s have rear LSDs in them? most JDM ones do, but they're viscous LSDs. As Nikk said above, you can't have a plate/clutch type LSD with 4WS, so if you want a plate/clutch type LSD you'll have to lose the 4WS.
RedTwo
New Zealand
Que? What kind of japanese diff would take 3 years to find?
Are you keeping 3 bolt axles for scrutineering purposes? Seems like an odd choice.
Olson
Moreno Valley CA
I like the idea of the 4ws and since im going to japan i have time to look for one
Mark LaVallee
Shelton Mitsubishi 1983-2006 RIP
In reference to Fuel. No USDM Galant VR-4s ever came with any LSD.
Sold them when they were new.
fuel
Toronto, ON, Canada
What about the 1G DSM, do they come with an LSD and 4WS? Or LSD from a 3000GT with 4WS swapped into the diff housing of the GVR-4?
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
Why don't you get a 4-bolt viscous LSD from a DSM and retain 4WS?
4ws 4-bolt LSD swap Thread
Keep in mind I did this with an A/T LSD, so it wouldn't be as complicated.
jepherz
KC, Missouri
Quoting fuel:
Some DSMs had LSD, but none had 4WS.
