09 Lancer Ralliart Intercooler
Mark
Naperville, IL
The other day one of mechs was measuring a 09 i/c for bigger fitment. I was looking at the stock intercooler it looks like a real good fit for galants. I will take some picts but has one side pipe and one top pipe coming out which would work perfect for a vr4.
So keep look out for stock ralliart i/c.
EMX5636
Bucks County, PA
IIRC it is the same FMIC that is on the 08 EVO X. If anyone wants any pics or measurements I have one at work thats out of our shop car. Only issue I could see with it without trying to fit it, is it is pretty tall. It might not fit behind the trim piece under the headlights...
Mark
Naperville, IL
No it's not they are different. They are pretty simular thou the evo x is a little bigger thou.
EMX5636
Bucks County, PA
Post the measurements of the Ralliart one and I'll compare. Weird that they'd tool another I/C just for the RA...
Mark
Naperville, IL
If it's still off the car I will. Im sure we have a evo X one laying aorund to compare with also.. Let me see what we have at work.
Dialcaliper
Mountain View, CA
It's unlikely that they tool their own with all of the myriad heat exchanger cores out there (Bell for example, makes them for any dimensions, in increments of as little as .2 inches) It's more likely they simply purchase one from whichever OEM supplier they choose with standardized end tanks, in which case the smaller unit ends up cheaper (kind of like the JDM VR-4 vs RS IC's).
Quoting EMX5636:
IncorpoRatedX
Arizona
reviving an old thread.
Anyone put an "RA" Lancer Ralliart FMIC on their GVR4 yet??
Ralliart is the top, EVOX is the bottom.
Drew84
Peabody, Ma
I was thinking about using one of these when I was building my car. If you flipped these around they would line up pretty well with the factory pipes I think.
IncorpoRatedX
Arizona
thats the plan!
