Was a ZR4, now a VR4
JayRome
Member
Vic, Australia
Its been a while.... a long while..... unfortunately in that time, my widebody ZR4 was written off by a young driver who decided to drive head on into me at an intersection..
Lucky enough, i had built a VR4 for a friend who doesnt drive it that much and he decided to sell it to me... so a new project begins...
Build update shortly....
JayRome
Member
Vic, Australia
Pretty much stripped and swapped everything over. Rebuilt the HVAC system with new foam and clean insides, ripped out the old climate control and A/C and replaced with standard dials and deleted center vents. Ran wiring required for gauges etc while dash was out. Reinstalled my EvoX seats and Evo9 steering wheel.
Removed engine and gearbox.
Removed all the ABS crap, replaced with standard braking system and GTO brake master
Reinstalled my old built hybrid 6bolt/evo7 engine.
JayRome
Member
Vic, Australia
Fabrication:
Intercooler Aeroflow 300x600x75mm
Extremely short cold side pipe
Radiator from a VW with twin 8" fans and alloy shroud. Silicone hoses and modded inlet for swirl pot.
toybreaker
iconoclast
That is some impressive work! :bowdown:
JayRome
Member
Vic, Australia
Thanks!
Had to down grade brakes from my 6piston Porsche calipers, back to Evo 4piston calipers to clear Evo 7 wheels.
6X9 rear shelf adaptors, bolts into stock grill location no need to cut shelf (can be put back to stock)
(old mods, but thought i would post anyways)
Brake upgrades:
Front
Porsche 6 Piston calipers
350mm EvoX discs
Custom brackets
Custom braided brake line
JayRome
Member
Vic, Australia
Rear
Stock VR4 rear trailing arm
Subaru 2 piston calipers
Mitsubishi GTO rear discs
Custom brackets
CT9A Modified handbrake assembly
CT9A hand brake cable with adaptor to VR4
Custom brake lines
Interesting repair. Let us know how it works.
JayRome
Member
Vic, Australia
Its been a while. New location and waiting for garage to get built.
Evo X wheels (surprisingly hard to find for sale in Aus)
Testing 6 piston caliper clearance
Fresh coat of paint
225/40R18 tyres
Fitment: approx 10mm tolerance from rim barrel to caliper and 4mm from caliper to wheel spokes, no spacers needed.
BeerySquash
I knew those calipers looked familiar, I have a pair of them sitting in the shop from a Cayenne/Touareg, they're big units.
JayRome
Member
Vic, Australia
have been chasing a cooling isssue at "higher" speeds and realised that the only difference between the VR4 and the ZR4 were the bumpers... so here we go...
Took off 5.1kg of weight off the front bumper reo
Alloy air dam and some plastic garden edging to blend it all in....
JayRome
Member
Vic, Australia
Rear brake upgrade V2
Custom machined 350mm discs
Custom 190mm hand brake assembly
VAG group rear 4 piston calipers (matches the front 6 piston calipers)
Stock brake lines fit fine
E brake cable re used from last set up, from an evo8
Custom braket to suit
Old set up: Mitsu GTO/3000GT 296mm rear dics vs new 350mm disc
Caliper bracket:
E Brake:
Install:
Check over after bedding in and re bleed:
