Fuel filler hose
MitsuDriver274
Bellingham, WA
After sitting for quite some time, I filled up the tank in my VR4. Was welcomed the next morning with a pool of gasoline under the car.
The replacement hose is now discontinued, I did not have any luck finding a new hose. I was able to piece something together, figured I'd share what I was able to cobble up.
41MM Molded 90
41MM Molded 45
41MM Coupler
Used my old hose as a reference to cut the new hose, used the old zip tie mark as a reference for the splice.
New hose fits very well.
/ubbthreads/images/graemlins/worthy.gif
slugsgomoo
Tacoma, WA
I love that after all the years of people suggesting this when it happened, not only did someone do it, but took detailed pictures to help future folks. Nice work /ubbthreads/images/graemlins/laugh.gif
IncorpoRatedX
Arizona
Thank you for this.
makedollarz
Phoenix
Thank you for taking the time to write this up. Im bringing 202 back to life and this was the first problem i came across after sitting for so long...
I didn't think of this earlier, but as the failure of the original hose is basically (those I have seen) cracking at the lower elbow (left end of the original hose in the pictures above), you could just splice a 90* elbow to the original hose in the same manner with the joint.
Just another thought.
makedollarz
Phoenix
Mine was leaking from the lower elbow as you mentioned. I guess i could have got away with just replacing the lower portion i didnt think about that either. Parts will be here tomorrow.
