Gen 2 MAFT install... NEED HELP.....
GolfBall
Edmond, OK
so im working on gettin my vr4 running and am to the point where i need to wire up the Gen 2 MAFT to a 3" gm maf....
this is where im at....
been searching and reading everywhere and cant find anything helpfull.... the combo of being a 1g vr4 with dsm-link and Gen 2 just isn't that popular i guess....
GolfBall
Edmond, OK
so does this sound right.....
MAFT
yellow-----yellow \
pink---------red MAF
black------black /
black------green/black \
green-----green/blue STOCK
grey-------green/yellow MAF WIRING
brown-----green/orange /
1. Purple - not used
2. Brown - not used
9. White - not used
onesickcrx
NY
I'm at my buddys shop helping him paint his truck. when I get home I will see which wire goes where on my car. Unless someone posts it first
onesickcrx
NY
Sorry I wired it up on the car I just sold and I didnt take any pictures /ubbthreads/images/graemlins/frown.gif
GolfBall
Edmond, OK
how has no one had this problem....
i cant find this info ANYWHERE..... cant even find a simple wiring diagram to tell me what wire does what, everything just shows pins at the ecu.
I'm not sure why you are so confused. The documentation is pretty clear. This is their diagram, as to which color wire on their box goes to which pins on the ECU.
You just need to correct the colors for a GVR-4, which is documented pretty well in the 2GMAS-in-a-1G VFAQ:
You don't need the wire from pin #1 of the original MAS, MAF Reset, because the MAFT doesn't supply a Reset signal. That still leaves you with the problem of tracing which Green/Yellow wire goes back to pin #16 of the ECU, so the MAFT can lock the BARO signal. (They have pin #1 of the MAS plug labeled "Idle Position Switch", just ignore it.)
You also don't need the wire from pin #4, the Green/Red striped +5 volt feed for the BARO section, as the MAFT runs off of 12 volts only, the heavy Red wire that was on pin #3 of the MAS connector.
Green/Orange is IAT, pin #8 of the ECU.
The Green/Light Blue wire that was pin #2 (to pin #10 of the ECU) is the Karman Hz wire.
For a ground to the MAFT unit, you can either source a good ground to chassis or somewhere, or I guess you could use the Sensors Ground, which is on pin #6 of the MAS, Green/Black striped wire.
