Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Boost gauge install pic..
Micah
Galant VR-4 org Post #: 61761 posted 05/14/03 11:17 PM     Remind Me!  Send Private Message   Edit Post
Just thought I would finally post this pic of my gauge install. It took far too much work for what it is but at least I am very happy with it. And it works perfectly (after many hours of tinkering). Sure hope someone else appreciates it.  -
Micah.
| | | IP: (216.187.161.70) | Report this post to a Moderator
Xan
Galant VR-4 org Post #: 61762 posted 05/15/03 12:03 AM     Remind Me!  Send Private Message   Edit Post
that is so badass man, too bad I have 2 gauges I need, otherwise for just one that is killer.
| | | IP: (12.245.0.93) | Report this post to a Moderator
chhuong
Galant VR-4 org Post #: 61763 posted 05/15/03 12:04 AM     Remind Me!  Send Private Message   Edit Post
Very very nice!! looks stock!! Good job!!
| | | IP: (12.231.60.103) | Report this post to a Moderator
DookGVR4
Galant VR-4 org Post #: 61764 posted 05/15/03 12:10 AM     Remind Me!  Send Private Message   Edit Post
definitly looks great [Cool]
| | | IP: (24.52.237.20) | Report this post to a Moderator
rick r
Galant VR-4 org Post #: 61765 posted 05/15/03 12:12 AM     Remind Me!  Send Private Message   Edit Post
l have to ask because l`m constantly diving into detail oriented jobs that end up taking waaaay too long (but look cool)....just how long did it take? don`t lie either.l bet the next one will be a breeze though. [Smile]
| | | IP: (68.35.24.131) | Report this post to a Moderator
4orced4door Galant VR4.org Moderator
Out Standing
Galant VR-4 org Post #: 61766 posted 05/15/03 12:19 AM     Remind Me!  Send Private Message   Edit Post
Awesome install. Isn't it harder to look down there than to the A-Pillar to see how much you are boosting though? Although if you're just going for a stealth, clean look, you hit the nail on the head. I just don't know if that's as easy to read as a 60mm gauge on the A-pillar right in your face.
Posts: 9846 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (65.33.242.24) | Report this post to a Moderator
RayH
561/1000
Galant VR-4 org Post #: 61767 posted 05/15/03 12:27 AM     Remind Me!  Send Private Message   Edit Post
I appreciate the amount of work since I did the same thing a while back. Knowing exactly where it's going before cutting and breaking plastic was key. I lucked out with mine and was able to mount it right through one of the existing auto transmission indicator bulb holes which also put the gauge flush with the existing ones without any shimming. Having a blank spot on the flex circuit board directly behind where the hose needed to go through didn't hurt either.
Posts: 2700 | From: NJ | Member Since: 04/09/01 | IP: (67.82.160.28) | Report this post to a Moderator
mromik
Galant VR-4 org Post #: 61768 posted 05/15/03 01:05 AM     Remind Me!  Send Private Message   Edit Post
good deal
but why not to read the stock boost gauge.
I.ll do the same! may be...
DOES ANYBODY HAS electrical boost sensor?
| | | IP: (212.16.192.65) | Report this post to a Moderator
Vr4in'
Galant VR-4 org Post #: 61769 posted 05/15/03 01:08 AM     Remind Me!  Send Private Message   Edit Post
Good job man!
It looks great! [Big Grin]
| | | IP: (65.32.218.225) | Report this post to a Moderator
udriveu
Galant VR-4 org Post #: 61770 posted 05/15/03 01:09 AM     Remind Me!  Send Private Message   Edit Post
Looks like it belongs there. VERY nice work.
| | | IP: (64.252.97.167) | Report this post to a Moderator
theymightbegalants
Galant VR-4 org Post #: 61771 posted 05/15/03 03:07 AM     Remind Me!  Send Private Message   Edit Post
quote:
Originally posted by mromik:
good deal
The stock boost gauge isn't really a boost gauge. It "predicts" what the boost should be based on a number of inputs such as air flow and throttle position. It's really only useful for determining if you have a boost leak (stock gauge shows boost, aftermarket shows none) or if you have a Keydiver ECU.
Very, very nice install job. Me like.
| | | IP: (134.10.23.206) | Report this post to a Moderator
dsmsleeper
Galant VR-4 org Post #: 61772 posted 05/15/03 09:26 AM     Remind Me!  Send Private Message   Edit Post
Wow! Awesome job. It looks great. [Big Grin]
| | | IP: (63.146.62.141) | Report this post to a Moderator
markrieb
Galant VR-4 org Post #: 61773 posted 05/15/03 09:35 AM     Remind Me!  Send Private Message   Edit Post
If you really want a stroll down memory lane or to see just how far we have come, look for Ray's posts to the original talon digest.
Mark Rieb
Posts: 612 | From: Kennewick, WA, USA | Member Since: 02/23/01 | IP: (206.219.255.152) | Report this post to a Moderator
Micah
Galant VR-4 org Post #: 61774 posted 05/15/03 11:12 PM     Remind Me!  Send Private Message   Edit Post
It probably took me 24 hours total time or more, but I did it over a couple of times. All kinds of issues I had with it. Where I had the hose going the first time made the gauge want to rotate to the left. I didn't support it well enough the first time and it tore through some of the connections on the circuit board. Fixed those, then had the fixes break. Got another board from a local guy thats been very nice. Also had the gauge parts hitting the trip meter mechanicals and reading inaccurately. And yes it is harder to read where it is than a pillar pod, but I didn't want everyone that pulls up beside to see a gauge or two sitting right there. And Mark I didn't really understand what your post meant. thanks again, Micah.
| | | IP: (216.187.162.8) | Report this post to a Moderator
silly4turbo
Galant VR-4 org Post #: 61775 posted 05/15/03 11:36 PM     Remind Me!  Send Private Message   Edit Post
that looks totally steath ! great job .. has anyone tried mounting a boost gauge off the "hood"
of the intrument panel, it would hang right between the tach and the speedo ?
| | | IP: (129.44.165.2) | Report this post to a Moderator
RayH
561/1000
Galant VR-4 org Post #: 61776 posted 05/15/03 11:51 PM     Remind Me!  Send Private Message   Edit Post
I had the same initial problem with the gauge mechanical coil bumping into the odometer and not reading above a certain psi. Also mine isn't backlit since I used an old HKS gauge which was supposed to be sidelit. Was planning on installing a small led to light it but never got around to it.
The cool thing is seeing all three needles turn together when you floor it and the goal is to have all of them parallel to each other pointing somewhere to the right [Smile]
Posts: 2700 | From: NJ | Member Since: 04/09/01 | IP: (167.211.190.2) | Report this post to a Moderator
TLT
Galant VR-4 org Post #: 61777 posted 05/15/03 01:57 PM     Remind Me!  Send Private Message   Edit Post
And even if it was accurate, its 5 blinking lights. You wouldn't be able to tell what psi you were at anyway.
| | | IP: (216.63.145.85) | Report this post to a Moderator
SEVEN26
Galant VR-4 org Post #: 61778 posted 05/16/03 12:16 AM     Remind Me!  Send Private Message   Edit Post
uno. i have a lot of respect for you now. that looks amazing. i don't care if its a little more work to look at than on the a pillar... it just seems to be at home there. very nice. so clean its just amazing. if you spend that much time with you car on the installs and it turns out that nice, i'd have to see more of it. post more pics. [Smile]
| | | IP: (24.27.68.183) | Report this post to a Moderator
markrieb
Galant VR-4 org Post #: 61779 posted 05/16/03 10:10 AM     Remind Me!  Send Private Message   Edit Post
For you newbies, Ray H (along with Nate Pharr and Ron Gregory) is one of the members that has been playing with his GVR-4 since the original Talon Digest was started, and long before we ever had a separate GVR-4 playground.
Ray did the Boost Gauge in the Dash mod back around 1995 or so and posted about it in the Talon Digest, along with a bunch of other GVR-4 mods.
If you have read the Talon Digest archives you would be surprised at how far we have come. Like how the very first VFAQ ever written (before Tom Stangl started VFAQ.com) was written by Nate Pharr on how to install an upgraded fuel pump in a GVR-4. It was GVR-4 guys who figured out how to modify the window switches so that you could have "auto up" as well as "auto down". And I think it was GVR-4 guys that figured out how to mod the fog light switch to allow the fogs on at any time, not just with the low beam headlights.
Just a little history lesson and a hello/welcome back to an old friend/member.
Mark Rieb
Louters91GVR4
Galant VR-4 org Post #: 61780 posted 05/16/03 10:27 AM     Remind Me!  Send Private Message   Edit Post
that is AWESOME. looks factory style. i will pay you to do mine;)
tom
| | | IP: (216.153.165.31) | Report this post to a Moderator
199of2k
Galant VR-4 org Post #: 61781 posted 05/16/03 04:31 PM     Remind Me!  Send Private Message   Edit Post
Does the boost gauge also sport switchable illumination? Great job by the way
| | | IP: (68.14.148.59) | Report this post to a Moderator
number3
Galant VR-4 org Post #: 61782 posted 05/16/03 04:45 PM     Remind Me!  Send Private Message   Edit Post
I miss the digest. The old digest. I still have old copies I printed out, of certian ones that I used as references. Most date from the early months of 1996.
Harry
Posts: 7623 | From: KoP, PA | Member Since: 06/26/01 | IP: (68.80.13.73) | Report this post to a Moderator
Generated in 0.255 seconds in which 0.217 seconds were spent on a total of 14 queries. Turbo powered.
