This car was Jared Hansen's car, I baught it about 7 months ago and have since baught a new house and had a kid. The car is just sitting in the garage not being driven. There are a few additions to the car since he had it (which is the description below.) It now also has a Forrester intake manifold on it, as well as a profec b controller. The car has zero rust, and the interior is all new in it. New black leather, no cracks on dash... this is a very nice car. The car was tuned down to about 300hp when I bought it, but I will have it in the 400-450 range when I sell it. The tuning is all being done by a reputable megasquirt guy, DieselGeek, if anyone follows megaquirts and DSM's you know who he is.
I included a couple pics. Yes Jared, if you see this I hacked the pics from you. /ubbthreads/images//graemlins/smile.gif
Here is a list of the stuff on the car.
Year: 1991
Number: 218/2000
Best 1/4 mile time: 12.94 @ 103
Dyno Numbers: 519WHP / 435WTQ
Power:
Comp 101200 Cams
Mitsu 4 layer HG
ARP Headstuds
Megasquirt V3 Standalone EMS
Bar and plate Core with Custom Piping
Tial Knockoff BOV
Freshly Rebuilt Head with new seals and 3 angle valvejob
3 inch mandrel bent stainless exhaust and down pipe
SBR GT14BB Turbo
Stainless Oil and Coolant lines for turbo
Tial 40mm Wastegate with o2 Dump
1000CC injectors
Walbro 255hp fuel pump
Dentsport stainless steel fuel pump housing
Stainless fuel line with 6AN fittings Tank to Filter
Stainless Filter to rail line
Stainless Fuel Return line
Aeromotive FPR
Stainless steel exhaust manifold studs
TurboXS MBC
Balance shafts removed
Forced Performance Intake Pipe
DriveTrain:
Switchable transfercase FWD/AWD
4bolt LSDrearend conversion
4WS removed
TRE rebuilt trans
Quaiffe front LSD
Stainless clutch line
Some type of short shifter with leather shift boot
Steel shifter bushings
ACT 2600
Suspension/Handling:
Hot Bits Coilovers
Noltec camber/caster plates
Whiteline sway bars front and rear
Whiteline rear strut bar
Urethane bushings
ABS removed
Stainless brake lines
PS removed
GOLD Rota Subzero Wheels
Toyo Proxy4 Tires
Audio:
Clarion Headunit
Aftermarket Speakers ALL around
Year: 1991
Number: 218/2000
Power:
Comp 101200 Cams
Mitsu 4 layer HG
ARP Headstuds
Tial Knockoff BOV
SBR GT14BB Turbo
1000CC injectors
Aeromotive FPR
TurboXS MBC
DriveTrain:
4WS removed
TRE rebuilt trans
Quaiffe front LSD
ACT 2600
Hot Bits Coilovers
Urethane bushings
ABS removed
PS removed
Toyo Proxy4 Tires
Audio:
Clarion Headunit
