I started fabricating the tank for my water to air intercooler the other day. It tucks nicely up in the passenger side front corner in front of the wheel. Method for getting the dimensions is pretty easy. I calcuated the rough cube I needed from the cubic inches in 3 gallons. Then I tooks some measurements so that it would fit in the spot I wanted it. Next I cut out cardboard rectangles and taped them up to fit and then test fit the tank on the car. It didn't quite fit due to a little sheet metal so I made a little cutout in the upper part of the tank. Now it fits nicely and ended up holding right at 3 gallons. Now I've got the dimensions to cut the pattern out of 1/8" aluminum sheet and weld together /ubbthreads/images/graemlins/laugh.gif
