JackstandTSi
Im going to be replacing my bearings in my GVR4. I took off the Mains and they seem to look ok except for the rear which i noticed some copper starting to show, Front and Center seem ok. no copper showing. Im pretty un-expierenced when coming to stuff like this. Im not sure what to look for as of bearing wear and proper replacement and specs.
I got a few pics from my phone, i also grabbed some of the crankshaft to maybe someone on here can tell me if it looks to be in good shape.
Front Main
Center Main.
Rear Main
I noticed this little marking on the crank at the rear also right above the oil gally not sure if this is normal or not.
And the rest of the crankshaft look like this.
I plan to do some research on the size of the Crank to make sure it hasnt been cut so i know to get the proper size bearings, I think im going to repolish the crank if it needs it but other than that i just want to put some matching bearings in and go.
Thank you
Front Main
Center Main.
Rear Main
Thank you
