Greddy typeS knock off help
James
Port richey Florida
So after some research after yesterday's fiasco, I did some research because I had No idea what the lower Nipple was for on this BOV. The previous owner had it capped off like a moron.
I know it can be left open or run to a dedicated boost source, my question is what should the nipple be doing. When I uncapped it it was sucking MAJOR vacuum at idle. Should it be sucking air all the time like that?
James
Port richey Florida
Wel after 3 hours of reading I've come to the conclusion that the reason the lower nipple is sucking air is because the diaphragm is ripped. New BOV on the way, guess I'll stay out of boost till it gets here.
James
Port richey Florida
i know trust me. i wouldnt spend my money on one. it was on the car when i bought it. I would use a 1b BOV before anything else!
im just slowly trying to fix the last owners mistakes.
alansupra94
Wayne,NJ
I actually have a knock-off Greddy BOV with a real Greddy BOV diaphram. Found the diaphragm in the basement one day and decided to try it out. Works great.
Gombos
irwin,pa
I've even seen the real greddy diaphrams rip quite often. Seems like some have pretty good luck with replacing the diaphram with an NGR brand diaphram though. Either way, if it were me, I'd stick with a 1g BOV until it wasn't enough, and at that point it would be either a TiAL or Turbosmart.
