Fuel pump relay
Hello: I'm looking for the fuel pump relay on my 1992 GVR-4 but haven't found it yet, can anyone please tell me the exact location of this?
Thanks.
Well I just looked for behind the glove box which I removed completely it but there isn't, so I guess the guy that installed the Haltech EFI, had to removed and is missing now. It seems I will have to make my own relay connection but simple energizing the fuel pump with the key switch in On position and another hidden switch that allows to shut the pump off while main switch is On, it also can be used to prevent to be stolen.
Any other good idea?
Thanks.
holeshotmoe
VA
Also known as MFI Relay. CLICK here for relay & pump schematic.
Stock location...
^^^ Thank you very much, finally I could find it and plug the fuel pump wire as it used to be before using the Haltech. The car works again /ubbthreads/images/graemlins/smile.gif
