throughfaith323
Hey GVR4.org,
I have a knock problem and was hoping someone here could help.
MODS:
-EVO 3 16G (18psi)
-EVO intercooler with 2.5" piping
-BC 272 cams
-EVO/3g maf
-FIC 950cc injectors
-Base pressure: 44psi
-Global fuel: -56.6%
-Deadtime: 360usecs
-Walbro 255
-ECMlink
After installing the E3-16g, along with a bunch of other mods, I wanted to try and tune the car with a few pointers from my friend(first time ever trying to tune)....
Here is what I did:
1. Set the fuel adjustments for the 950cc injectors.
2. Brought the timing table to zero.
3. A few other things.
4. Went for a drive and logged a 3rd gear pull.
The AFRs seemed to be pretty good at WOT so my method from here was to keep on advancing timing until I noticed substantial knock popping up. I could not advance timing even 1 degree without making the knock increase. There is something wrong here correct? Timing advancement should increase with rpm's and I seem to have the opposite effect.
I thought my knock sensor was shot when I looked at it and the goo was completely missing. I switched it out with another knock sensor I had lying around and this did not change a thing. I thought for sure I had a bad knock sensor.
Below are screen-shots of the 3rd gear pull "LIVE datalog", timing table, and fuel adjustments respectively. Maybe something sticks out from this data that could point me in a certain direction?
Where should a go from here? Any suggestions would be very much appreciated!!
THANK YOU!!
Ed
MODS:
-EVO 3 16G (18psi)
-BC 272 cams
-EVO/3g maf
-Deadtime: 360usecs
-Walbro 255
-ECMlink
Here is what I did:
THANK YOU!!
Ed
