Galant VR-4 Forums » Galant VR-4 » Newbies » brake bleeding order?
groovedmb
Galant VR-4 org Post #: 349523 posted 06/14/06 10:13 AM     Remind Me!  Send Private Message   Edit Post
real quick, what is the bleed order for our cars? Also, are there any tips for bleeding brakes on a VR4?
| | | IP: (216.9.250.61) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 349524 posted 06/14/06 10:15 AM     Remind Me!  Send Private Message   Edit Post
Farthest from brake master cyl to the closest. Rear Rt, Rear Lt, Front Rt, Front Lt.
Edit: [Corrected] See Below!
-mitsuturbo
Edited by Hertz (06/15/06 07:29 AM)
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
Polish
Dr. Pilosh Haagenscodyberger
Galant VR-4 org Post #: 349528 posted 06/14/06 10:27 AM     Remind Me!  Send Private Message   Edit Post
I just did mine and it went real smooth. In the order Steve mentioned. No tips for you really because it was easy. Don't forget to turn the front wheels, it makes it easier to reach them.
My car site
Old GVR4 #1186/2000
Posts: 8936 | From: NE, IN | Member Since: 01/10/05 | IP: (69.245.199.84) | Report this post to a Moderator
Nijasan
polevault tard
1373/2000
Galant VR-4 org Post #: 349586 posted 06/14/06 12:51 PM     Remind Me!  Send Private Message   Edit Post
What's the trick to bleeding that hard-to-reach bleeder screw on the ABS unit? The one closer to the fender, the front one is easy to get to, but the back one seems impossible with all the hard lines surrounding it like bamboo surrounding Charlie in the lush jungles of 'nam.
Posts: 724 | From: Yuba City, CA | Member Since: 09/03/04 | IP: (206.14.213.30) | Report this post to a Moderator
Polish
Galant VR-4 org Post #: 349589 posted 06/14/06 12:56 PM     Remind Me!  Send Private Message   Edit Post
My ABS is eliminated, can't help you there.
My car site
Old GVR4 #1186/2000
GVR-4
Creative Name Huh?
77/1000
Galant VR-4 org Post #: 349751 posted 06/14/06 09:06 PM     Remind Me!  Send Private Message   Edit Post
I think the correct order is
1)Right Rear
2)Left Front
3)Left Rear
4)Right Front
I wrote it down on an index card years ago; I think it came from a manual or an FAQ. The order makes sense if the diagonally opposite wheels are paired, which I'm pretty sure they are.
Dave Peter
Can't polish a turd.
Posts: 2599 | From: Asheville, NC USA | Member Since: 04/22/02 | IP: (24.179.23.184) | Report this post to a Moderator
dsm_drew
Galant VR-4 org Post #: 349804 posted 06/14/06 11:58 PM     Remind Me!  Send Private Message   Edit Post
That is correct. The right rear and the left front are on one "circuit" together. The left rear and right front are on the other. You want to completely bleed one pair before you do the other. It will still work if you bleed both rears, then both fronts, but the diagonal sequence is technically correct.
| | | IP: (67.187.119.98) | Report this post to a Moderator
Polish
Galant VR-4 org Post #: 349836 posted 06/15/06 06:22 AM     Remind Me!  Send Private Message   Edit Post
What about if the ABS is pulled, does that remove that "circuit" because I assume thats built into the ABS unit?
My car site
Old GVR4 #1186/2000
dsm_drew
Galant VR-4 org Post #: 349839 posted 06/15/06 06:30 AM     Remind Me!  Send Private Message   Edit Post
ABS doesn't matter, its the master cylinder and proportioning valve that splits them. Built that way so if you were to pop a brake hose or a caliper you would still have one front brake and one rear brake to stop with.
Polish
Galant VR-4 org Post #: 349846 posted 06/15/06 06:38 AM     Remind Me!  Send Private Message   Edit Post
Alright then, makes sense.
My car site
Old GVR4 #1186/2000
CP
Galant VR-4 org Post #: 350358 posted 06/16/06 01:19 PM     Remind Me!  Send Private Message   Edit Post
It doesn't really matter just as long as you're using new fluid, and start with the rears. Get some speedbleeders so you don't have to keep cracking and tightening the bleeder screws after each pump. These also allow you to do it yourself, since the check valve closes with the up-stroke of the pedal and won't let any air into the calipers.
While on this topic, what are some symptoms of the master cylinder going south?
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.4) | Report this post to a Moderator
Polish
Galant VR-4 org Post #: 350372 posted 06/16/06 01:53 PM     Remind Me!  Send Private Message   Edit Post
On my old Acura the pedal got real mushy. Eventually falling to the floor after 2 seconds of braking, made driving quite the challenge. It was an Auto too.
My car site
Old GVR4 #1186/2000
2 registered and 12 anonymous users are browsing this forum.
Generated in 0.113 seconds in which 0.081 seconds were spent on a total of 14 queries. Turbo powered.
