Galant VR-4 Forums » Galant VR-4 » Newbies » Replaced blown intercooler pipe, runs terribly NO BOOST LEAKS
yubh8tn
1384/2000
Galant VR-4 org Post #: 1250747 posted 05/13/21 03:23 AM     Remind Me!  Send Private Message   Edit Post
I know what you're thinking. I have a boost leak, you're gonna say. BUT I DONT. I tested and it's holding 20psi just fine. The problem is very weird because it is running rough on idle, runs fine at cruising speed, but bogs like i blew an intake pipe when I floor it and the turbo is spooling 1-2k rpms later than it did with the factory hose.
I replaced the pipe with a homemade radiator hose setup and it ran just fine except it took forever to spool, so I tested for leaks, it had one, and changed how I had it connected to the intercooler. Now its running terribly but holds boost. The check engine light comes on during pulls and there's a loud ticking sound that scales with RPMS near/around the intake manifold.
I know you guys can't do much without being with the car and seeing what I did, but any guesses would be appreciated. Thank you
Belize Green 1384/2000
1998 Integra
Edited by yubh8tn (05/13/21 03:25 AM)
Posts: 116 | From: coeur d alene, idaho | Member Since: 08/21/19 | IP: (66.222.63.21) | Report this post to a Moderator
mooserage Galant VR4.org Administrator
New Title
254/2000
Galant VR-4 org Post #: 1250752 posted 05/13/21 04:17 PM     Remind Me!  Send Private Message   Edit Post
By RPMS, do you mean the CAS?
Posts: 1256 | From: Seattle, WA | Member Since: 05/17/04 | IP: (205.166.76.242) | Report this post to a Moderator
yubh8tn
1384/2000
Galant VR-4 org Post #: 1250758 posted 05/13/21 09:14 PM     Remind Me!  Send Private Message   Edit Post
By scales with RPMs I meant the ticking gets faster when I rev the car. Could the CAS cause that?
1998 Integra
Edited by yubh8tn (05/13/21 09:14 PM)
Posts: 116 | From: coeur d alene, idaho | Member Since: 08/21/19 | IP: (98.146.240.111) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1250760 posted 05/14/21 07:45 AM     Remind Me!  Send Private Message   Edit Post
Did you leave a rag in one of the pipes?
Ticking sound could be the PCV valve clacking away. I used to get that at idle sometimes until I deleted it.
I love my crazy mother!!!
Edited by CutlassJim (05/14/21 07:47 AM)
Posts: 1673 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1250764 posted 05/14/21 01:26 PM     Remind Me!  Send Private Message   Edit Post
Also sounds like horrible lifter tick. Double check oil level.
At your own risk. Unplug the knock sensor with SAFE boost, and see if it runs better.
1992 Nile black w/sunroof
Posts: 6007 | From: central Indiana | Member Since: 08/06/02 | IP: (142.79.57.1) | Report this post to a Moderator
yubh8tn
1384/2000
Galant VR-4 org Post #: 1250768 posted 05/14/21 10:09 PM     Remind Me!  Send Private Message   Edit Post
No rag!! lol. The knock sensor is brand new OEM but its from a 1.8L Galant, according to a few various sites they're the same though. On top of that I got it tuned with that knock sensor installed and there wasn't a problem until I messed with my intercooler pipe.
Oil level is fine but I could add a bit more, PCV valve is brand new but I guess it could be that.
I guess I didn't make myself clear, the ticking sound and CEL are new. They didn't start until I changed the intercooler pipe. I'm going to revert the pipe to the busted one that I taped together and see if it runs correctly again. If it does then I know the bogging and weird idle were due to how I connected the hosing. Hopefully the ticking and CEL go away with that fix....
1998 Integra
Edited by yubh8tn (05/14/21 10:12 PM)
Posts: 116 | From: coeur d alene, idaho | Member Since: 08/21/19 | IP: (162.218.182.11) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1250772 posted 05/15/21 06:35 AM     Remind Me!  Send Private Message   Edit Post
Lifter tick can trip the knock sensor and enough knock can trip a CEL. Not saying that's what it is, but it could be a new symptom that is unrelated to your changes. Going back to how it was before you had a problem is a good choice, but I don't see how a IC and intake noise could be related. Hopefully something wasn't in the pipe that got sucked into the intake. Maybe do a compression check.
Posts: 6007 | From: central Indiana | Member Since: 08/06/02 | IP: (184.170.166.66) | Report this post to a Moderator
yubh8tn
1384/2000
Galant VR-4 org Post #: 1250782 posted 05/16/21 01:34 AM     Remind Me!  Send Private Message   Edit Post
I agree. We shall see! I'll post updates so if anyone has a similar issue they'll have some info.
Compression check is a good idea too.
1998 Integra
Generated in 0.071 seconds in which 0.053 seconds were spent on a total of 14 queries. Turbo powered.
