Galant VR-4 Forums » Galant VR-4 » Newbies » New owner, hello new friends
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250668 posted 04/26/21 03:47 PM     Remind Me!  Send Private Message   Edit Post
Hello everyone, I am new to the dsm/gvr4 and even new to the mitsu brand.
I have picked up #1519/2000 and have been working on it now for about a month replacing odds and ends, I cannot seem to figure out a metal on metal sound from the front but its still on going. not sure what else to put here but I am sure that I will be looking to you guys for some assistance and am going ahead and thanking you all for the guides that I have already used. And, man this car came with a trunk full of oem spare parts that I am still trying to go through.
If anyone has a C5 center cap.... ooooof I would love you
Take care!
Edited by Brigandine (04/26/21 04:15 PM)
Posts: 17 | From: Norfolk | Member Since: 03/30/21 | IP: (2600:8805:1716:4) | Report this post to a Moderator
Galant VR-4 org Post #: 1250681 posted 04/29/21 08:32 AM     Remind Me!  Send Private Message   Edit Post
Welcome. Car looks nice. OE parts are getting harder to get, so you may have a good resource there.
What kind of sound? Rotational? Vibrational?
Could be lots of things, but check the bolts to the block that mount the fixed shaft for the LH front axle shaft. They use a special shoulder bolt and sometimes are replaced with something else and can loosen.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10851 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250684 posted 04/29/21 07:35 PM     Remind Me!  Send Private Message   Edit Post
Hello
it seems to be rotational and variable by speed. it may just be pads sitting against the rotor, but i bought another caliper and its unlikely that another one is doing the same thing. I have a bearing and seals that I am going to try and have pressed, but plan to order both axels for the front to do it all at the same time. Other than that I need to figure out this silly boost controller as its peaking out over 25psi, then look to tune it, but im very unfamiliar on what to look imto for that.
Thank you!
Galant VR-4 org Post #: 1250701 posted 05/03/21 11:22 AM     Remind Me!  Send Private Message   Edit Post
Post what type it is. Someone may have experience.
Basically you need to determine how it adjusts and then dial it in with testing.
TheDude
Newbie
1853/2000
Galant VR-4 org Post #: 1250704 posted 05/03/21 07:27 PM     Remind Me!  Send Private Message   Edit Post
I have a metal on metal sound too..
my downpipe/exhaust rattling against the transfer case.
maybe you have the same problem never know
Posts: 6 | From: Temple, OK | Member Since: 05/02/21 | IP: (2600:8803:d803:9) | Report this post to a Moderator
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250708 posted 05/04/21 05:28 PM     Remind Me!  Send Private Message   Edit Post
Heyo, Well i have changed the DS caliper up front, and the sound was no different it sooooounds like pad drag, like just ever so soft. The PO left a bearing and 2 seals so i will be swapping that. I also will be going ahead and ordering 2 new axels and just send it with that too. can anyone think of anything else that i should do while I am down there?
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250709 posted 05/04/21 05:29 PM     Remind Me!  Send Private Message   Edit Post
I dont think it would be the downpipe as its speed dependable, not rpm.
TheDude
Newbie
1853/2000
Galant VR-4 org Post #: 1250711 posted 05/04/21 06:15 PM     Remind Me!  Send Private Message   Edit Post
Do you still have your ABS?
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250716 posted 05/05/21 08:32 PM     Remind Me!  Send Private Message   Edit Post
Negative, no abs
lowcashleblanc
231/1000
Galant VR-4 org Post #: 1250721 posted 05/05/21 11:49 PM     Remind Me!  Send Private Message   Edit Post
Things it could possibly be.
Engine and trans zone: oil pump, water pump, timing components, alternator, starter. AC pump if you still have it. Potentially something in the trans. Clutch assembly could be a source. Thrust and throw out bearing.
Wheel hub assembly zone: wheel bearing, pads on rotors, worn pads, Seizing calipers, just because you changed it with a good used or new part does not mean itís not defective. You have aftermarket wheels, you could have tire clearance issues.
Posts: 88 | From: Denver CO | Member Since: 03/19/13 | IP: (73.34.172.4) | Report this post to a Moderator
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250724 posted 05/06/21 08:47 AM     Remind Me!  Send Private Message   Edit Post
"Engine and trans zone: oil pump, water pump, timing components, alternator, starter. AC pump if you still have it."
none of this is speed sensative. its rpm sensative yes. But if i go 45 miles an hour, hear it, then shift into neutral. the sound still remains as if i were in gear.
I dont beleave it would be a clearance issue, as it came out of no where after about 3 weeks of driving.
if its the calipers that would be mega unlucky to have the same failure but not impossible.
pads on rotor, or bearing is whats I think it is, just need to get it pressed in
lowcashleblanc
231/1000
Galant VR-4 org Post #: 1250726 posted 05/06/21 11:17 AM     Remind Me!  Send Private Message   Edit Post
If it is happening at 45 mph and not anywhere lower itís probably not wheel bearings. Youíd most likely hear it from the get go if it was. Same if was your pads on rotors.
If itís happening when you drop out of gear and are coasting in neutral my bet it on pilot or throw out bearing.
TheDude
Newbie
1853/2000
Galant VR-4 org Post #: 1250731 posted 05/06/21 06:19 PM     Remind Me!  Send Private Message   Edit Post
my abs is deleted as well and the driver's front pad drags... on the inside
even after taking off the caliper , compressing the pistons again same result
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1250733 posted 05/07/21 06:50 AM     Remind Me!  Send Private Message   Edit Post
either replace the caliper or rebuild it, most likely has a rip in the boot and moisture got inside behind the piston, causing things to rust.
92 Galant VR-4 362/1000
76 ColtGalant Hardtop
79 Colt Sigma Wagon -1UZ Swap!
88 Fiji Blue Starion
94 Montero SR
Edited by raptorWagon (05/07/21 06:50 AM)
Posts: 2793 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (2601:601:4500:33) | Report this post to a Moderator
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250765 posted 05/14/21 08:45 PM     Remind Me!  Send Private Message   Edit Post
after doing some digging on a throw out bearing, it seems that it is not the case as it is simply able to be heard more, no engine noise or exhaust.
does anyone have a lead on a rebuild kit?
Posts: 17 | From: Norfolk | Member Since: 03/30/21 | IP: (2600:8805:1712:a) | Report this post to a Moderator
Imback
Newbie
Galant VR-4 org Post #: 1250769 posted 05/15/21 02:56 AM     Remind Me!  Send Private Message   Edit Post
Just buy a new caliper. I had a similar issue with my rear ended up being the caliper that wasn't making noise was causing my passenger caliper to do the work.The front's you can still find. The rears are a pain in the ass since i had to have them rebuilt.
1316
Posts: 7 | From: Suffolk,NY | Member Since: 10/27/17 | IP: (72.69.11.247) | Report this post to a Moderator
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250774 posted 05/15/21 07:34 AM     Remind Me!  Send Private Message   Edit Post
I havent tried a autozone or advanced yet, but the dealer could not find new, and said even if they could would be 600, each.
Brigandine
Newbie
1519/2000
Galant VR-4 org Post #: 1250786 posted 05/16/21 04:27 PM     Remind Me!  Send Private Message   Edit Post
I have taken off the caliper and one piston seems to drag, as in doesnt extend out as far as the other. not sure if that is normal
Galant VR-4 org Post #: 1250802 posted 05/18/21 01:47 PM     Remind Me!  Send Private Message   Edit Post
Caliper rebuild kits should be readily available. I did a pair of stock VR4 and a set of '05 Outlander version calipers last winter. I bought them through either Rock Auto or eBay, can't remember for sure. I usually use the Centric parts info on Rock auto for specs, as they have a good website with dimensional data for most parts.
Edited by iceman69510 (05/18/21 01:49 PM)
0 registered and 33 anonymous users are browsing this forum.
Generated in 0.067 seconds in which 0.043 seconds were spent on a total of 14 queries. Turbo powered.
