799/2000 in Denmark
SRDK
Denmark
Just picked up this 1991 Galant VR4 after more then 10 years of search - VR4's are extremely rare in Europe!
SRDK
Denmark
This car was imported from the US to Europe by the original owner back in 2001. I found it in the Netherlands. it's now in Denmark.
The pictures don't do it justice - it's in very very great condition!
Nice find.
Enjoy!
bobdole
U.K.
Look clean for sure. Grants on new car.
idreamidrive
Murray, KY
That is clean.
Is that a plastic end tank radiator? If it is, it looks like it is in it's very end of life, due to the color discoloration (the brown color).
SRDK
Denmark
I Think it’s the factory radiator (Can anyone confirm?)
Do I need to replace it?
Cherry Hill, NJ
I agree it looks like a plastic end tank and if I were you, yes I would for sure 100% replace it asap. And then get ready to start replacing all the radiator hoses, I'd also do a thermostat and probably a water pump and timing belt components along with the all seals behind the belt on the car, spark plugs, wires, oil, filter and change all the other fluids. Trans, t-case, rear end, clutch fluid, brake fluid. Just freshen things up, the car will be happy and you will be happy with how it runs and how much longer it will last for you.
