Galant VR-4 Forums » Galant VR-4 » Newbies » balance shaft bearings
yeti
Nope still sticky fingers
Galant VR-4 org Post #: 1068820 posted 05/27/12 07:36 AM     Remind Me!  Send Private Message   Edit Post
I removed the bearings for the front balance shaft but cant get the rear one (front shaft rear bearing) to line up with its hole on the way back in, i have it jn the freezer now, any ideas?
Also can remove the rear shafts bearing completely and use it for the front rear bearing, if i break the other one
And im doing the bsek is the reason im dong this
~turbohair~
Posts: 797 | From: san diego california | Member Since: 10/13/10 | IP: (206.29.182.202) | Report this post to a Moderator
Jason G.
Bourne Employment Supremacy
Galant VR-4 org Post #: 1068824 posted 05/27/12 08:58 AM     Remind Me!  Send Private Message   Edit Post
Just making sure I read that correctly, you're doing a balance shaft elimination and trying to line up the hole on the bearing?
Did you read the vfaq?
Posts: 3279 | From: Anderson, SC | Member Since: 10/07/03 | IP: (149.55.30.100) | Report this post to a Moderator
dsm1990tsi
Newbie
Galant VR-4 org Post #: 1068825 posted 05/27/12 09:52 AM     Remind Me!  Send Private Message   Edit Post
You dont want the holes the line up.
Posts: 17 | From: Pottstown, Pa | Member Since: 08/09/08 | IP: (71.224.93.31) | Report this post to a Moderator
dsm10o0
Member ++
705/2000
556/1000
Galant VR-4 org Post #: 1068895 posted 05/28/12 12:47 PM     Remind Me!  Send Private Message   Edit Post
block the 2 front oil ports or else you wont have any oil pressure and say goodbye to that motor. You dont have to remove the rear bearing and you can just leave it as it is.
91 VR-4 705/2000
92 VR-4 556/1000
03 Evo 8 -New toy
05 Nissan Armada toy hauler
Posts: 680 | From: San Jose CA | Member Since: 06/16/10 | IP: (50.136.173.234) | Report this post to a Moderator
yeti
Galant VR-4 org Post #: 1068918 posted 05/28/12 05:14 PM     Remind Me!  Send Private Message   Edit Post
No i meant i couldent get the bearing to line up with its housing i know i had to block oil ports i did.
My bearing was mangled so i popped the rear shafts holeless bearing out and used it where the front shafts rear bearing goes, it popped right in.
No problem when theres.no bearing in the rear shafts side right because it gets fed by he shaft it self not a oil hole.->correct?
~turbohair~
Edited by yeti (05/29/12 03:34 AM)
Posts: 797 | From: san diego california | Member Since: 10/13/10 | IP: (68.7.143.172) | Report this post to a Moderator
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 1069021 posted 05/29/12 12:01 PM     Remind Me!  Send Private Message   Edit Post
In the interest of simplicity...
REAR: remove the shaft, done.
FRONT: remove the shaft, rotate old bearings (or install new/blanks), block oil passages in block, done.
The front bearing inside the block is a real pain in the ass. If I remember right, I managed to get it pretty close to started, then used the front shaft to guide it in. About halfway, it started to bind up on me, so I used a hammer to "gently coerce" it. Bearing is in there now. Forever. That shaft doesn't turn, either. Done and done.
Probably helps if you can rotate the engine on a stand to better see what you're doing. I had a head full of assembly lube and dripping wet lifters without a valve cover, so I had to do it from the bottom.
Brian | 98 Pajero | Gearbox Magazine
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (204.17.31.126) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1069040 posted 05/29/12 01:28 PM     Remind Me!  Send Private Message   Edit Post
Yes. If you flip the front balance shaft around, it works great as a cam bearing tool for the aft mounted bearing on the front shaft. IIRC i use it to push the bearing out of there as well. It's just the right size to barely go thru that bearing hole.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3537 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.54.255.35) | Report this post to a Moderator
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.054 seconds in which 0.042 seconds were spent on a total of 14 queries. Turbo powered.
