Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Daydreaming about wheels
Whoodoo
buff guys = good time but my dream is to fondle 1051
62/2000
Galant VR-4 org Post #: 936888 posted 10/05/10 04:19 PM     Remind Me!  Send Private Message   Edit Post
As some of you may know, my Rota's aren't going to cut it anymore because I want to put 3kgt trailing arms on 62 in order to get big brakes all around. This, consequently, requires me to do a 5 lug swap and, as my Rota's are 4 lug, I need to find some new wheels.
The easiest, most logical, cost effective, and available wheel would be stock evo, but I'm not a huge fan of evo wheels on the GVR4. Some cars pull it off very nicely, like the silver ggsx with evo 8's that someone here has (sorry I don't remember who you are, but your car is beautiful). I just don't think the evo 8's go with a black car; they're too flat on the outside. I like wheels that are a bit more rounded because it complements the nicely rounded shoulder line of the galant.
For example, here's my car now.
I absolutely love the look of these wheels. The color, and the style fit right in with what I want this car to look like when its finished.
example of evo 9 enkeis:
The evo 9's aren't as flat at the evo 8's and are even the same design as my Rotas, but there is a subtle roundness the my spokes that the enkeis don't have which just makes them not fit the car like I want. Even the evo BBS wheels are all flat-like. Basically evo wheels look good on the more angularly styled evo, not our more roundy old-skool styled galant.
So now, let me get into the meat of the discussion I want to have with you, my wonderful forum mates. I have had my eye on the performance option wheel from the infiniti G lineup. They are made by Rays and are forged so they are strong and light, but there are just a few problems...
WHEEL SPECS:
FRONT
Size: 19" x 8"
Bolt Pattern: 5 x 114.3mm
Offset: +33mm
Center Bore: 66.1mm
REAR
Size: 19" x 8.5"
Offset: +30mm
Center Bore: 66.1mm
First of all, they are HUGE. At 19 inches, I'd need to put some serious rubber bands on them - I'm thinking like 225/35/19's. I'd probably need to do some fender rolling and other tom-foolery inside the arches.
Second, they are staggered and I know the rears will be too fat, so I'd need to find 2 pairs of fronts, which will probably be a PITA.
Third, they are +30mm offset. +35 is known to work with negative camber, and that extra 5mm is bound to be yet another PITA.
Fourth, the center bore is 1mm too small, so they would have to be bored out to fit.
As far as getting big rims to fit, I know Bazeng has, or had, 19's on his AMG, FCR had 19x8's with 235/35/19's but had a fairly high ride height. More of you have run 18 inch wheels and made them look great (Garfield Wright, Boostin4door, RedTwo). I'm just not so sure about that extra inch. I don't want the car to look comical, and if they came in 18 inch flavor, I'd forget about all the other crap and just go for it.
What's your opinion on 19 inch wheels, getting them to fit, big wheels in general, and these ones specifically? Would they be worth it?
62/2k
Posts: 924 | From: Binghamton, NY | Member Since: 07/11/09 | IP: (98.111.86.120) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 936890 posted 10/05/10 04:24 PM     Remind Me!  Send Private Message   Edit Post
19's will ride too rough, IMO.
I had a friend who had 18's on his 2g, and he sold them because it was too bumpy.
I ran 17's for a while, and even that was kind of rough, but i suppose it's bearable.
Maybe someone on here has actually run 18's or 19's and can chime in about their experience.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3535 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.144) | Report this post to a Moderator
crankwalk
Galant VR-4 org Post #: 936891 posted 10/05/10 04:27 PM     Remind Me!  Send Private Message   Edit Post
With the center bore you can use a 1/4 in spacer and pull the face of the bore out so it wouldn't matter. 235s all around and probably a good amount of camber and I can see those working.
Will it look good? No clue.
| | | IP: (171.159.64.10) | Report this post to a Moderator
Jesh
Member +
898/1000
Galant VR-4 org Post #: 936904 posted 10/05/10 04:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting mitsuturbo:
I run 18's as my summer tires and up here in Alaska the roads are pretty bad. but the driving response is amazing! They are pretty bumpy and if i had to choose again i would get 17's. They don't do well on the gravel roads up here. ( just a side note... i originally wanted 17's but none were available, and the 18's were a good deal ) oh and I'm running stock suspension.
But if you want to run 19's... i say go for it!
'92 Galant VR4 898/1000
'91 Galant GSX - parts
'93 Laser RS - gone
Posts: 282 | From: Soldotna, Alaska | Member Since: 11/12/09 | IP: (209.112.145.182) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 936936 posted 10/05/10 06:14 PM     Remind Me!  Send Private Message   Edit Post
Quoting cherrod8:
If your going to go for Rays wheels then why not a pair of 17x8.5 Time Attack TE37's, btw the time attack are black with the red pin stripe along the lip. Matter of fact I think there might be a pair sitting in my house for $1500
I think he'd want all four wheels, rather than just a pair.
97 CBR900RR
Posts: 3535 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (76.28.228.51) | Report this post to a Moderator
BrandonEchols
Snow White
477/1000
12/1000
Galant VR-4 org Post #: 936940 posted 10/05/10 06:25 PM     Remind Me!  Send Private Message   Edit Post
Quoting cherrod8:
Those are a very nice wheel.
But truthfully, if I were to buy a Ray's made wheel...it'd be this one:
Probably in white, to match my car though.
What is hellaflush?
Mitsubishi = Must Involve Turbos, Suck Unless Boost Is Seriously High Inside
Posts: 793 | From: Anchorage, AK | Member Since: 01/18/10 | IP: (216.67.106.234) | Report this post to a Moderator
Galant VR-4 org Post #: 937036 posted 10/05/10 10:47 PM     Remind Me!  Send Private Message   Edit Post
Check out the new Enkei PF01 if you like that style wheel (as I do...).
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10768 | From: Michigan | Member Since: 03/05/01 | IP: (74.36.90.114) | Report this post to a Moderator
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 937073 posted 10/06/10 01:16 AM     Remind Me!  Send Private Message   Edit Post
With 19's I don't think you'll get it low enough to look good.
The fenders are plenty big enough, but the rear upper arm and the steering tie rod in the front get real close to the chassis before that becomes an issue.
JDM E39A - 0010362 VR-4 Project 燃えないゴミ(Unburnable Junk) - stolen
JDM E39A - 0020096 VR-4 Daily - sold
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (121.73.146.65) | Report this post to a Moderator
iLLeffeKt vr-4
Hertz pulverized mine
1759/2000
Galant VR-4 org Post #: 937105 posted 10/06/10 07:40 AM     Remind Me!  Send Private Message   Edit Post
Sound too complicated to make those G35 rims fit. Lets say you do all that (find 2 fronts, bore them out, etc) and they end up rubbing then what? Another thing is why get rims that are wide (8" in your case) and only put a 225 tire on it? I had evo rims on my vr4 with 245/40-17 tires. If the road are bad in your are good luck with those low profile tires. I would just go with some 18" rims if I were you.
Adrian
1759/2000 Summit White Sold
1991 Eclipse GS-X Sold
2013 EVO X MR - Daily
Posts: 2153 | From: NYC | Member Since: 07/26/04 | IP: (38.105.174.65) | Report this post to a Moderator
vegeta1170
Member +
1077/2000
Galant VR-4 org Post #: 937118 posted 10/06/10 08:30 AM     Remind Me!  Send Private Message   Edit Post
To run 19" wheels and not be 4 wheelin' or messing with the speedo, you would need to run like a 215/30 or 255/25 and since the first probably doesn't exsist and the second is just too wide, I would look for a 18" wheel instead.
I'm running 18" Enkei rs-7's on 225/35 rubber.
#1077/2000 Belize Green,
E3 16G Turbo, Exhaust Manifold, O2 Housing
18" gold Enkei Rims, Synapse BOV, E8 Suspension
Whiteline Sway bars, Dejon intake.
Posts: 338 | From: syracuse, ut | Member Since: 10/26/07 | IP: (67.139.146.6) | Report this post to a Moderator
Whoodoo
62/2000
Galant VR-4 org Post #: 937202 posted 10/06/10 01:56 PM     Remind Me!  Send Private Message   Edit Post
The PF01's are pretty much exactly the same as the wheels I have now. The spokes are a bit thinner, but not by much, thanks for finding them for me .
I think I am in agreement with everyone that 19 is too much. Even 18 can be too much if the car isn't done right. This wasn't a right away sort of thing, but I think it's been sufficiently concluded.
Damn, I really think they would look absolutely killer on the galant. Maybe I can get rays to cu$tom make me some 17x8 +38's
62/2k
iLLeffeKt vr-4
1759/2000
Galant VR-4 org Post #: 937216 posted 10/06/10 02:26 PM     Remind Me!  Send Private Message   Edit Post
I had a set of rota slipstreams in 17x8 with +38mm offset. I believe another member on here still has them on his car.
Adrian
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.23 seconds in which 0.193 seconds were spent on a total of 14 queries. Turbo powered.
