Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Windshield cowl weatherstripping
JR92
Newbie
104/1000
Galant VR-4 org Post #: 1247565 posted 10/23/19 08:52 AM     Remind Me!  Send Private Message   Edit Post
I removed my windshield wipers and cowl to get the rust off them and repaint them.The weatherstripping on top of the cowl is cracked and broken along the edges and I believe this is the cause of my leak that I get when it rains hard. Iím sure itís probably impossible to find an oem one but has anyone found a product that is an effective replacement? Was going to take it by my local glass shop to see if they had something, but wanted to check here first to see if someone else has done this.
Posts: 18 | From: Woodbridge, Va | Member Since: 04/04/17 | IP: (2600:1:f1a3:63c8) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1247568 posted 10/23/19 02:42 PM     Remind Me!  Send Private Message   Edit Post
aftermarket universal trim looks better than factory IMO, and seals great, it's what I've got on my car.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3684 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (192.195.4.32) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1247572 posted 10/23/19 08:29 PM     Remind Me!  Send Private Message   Edit Post
^^ OK but he's talking about the strip of rubber trip that runs along the top of the windshield cowl (under the wipers). You can even see the strip in your photo - it always ends up being an inch or two short on either side over the years as it shrinks and goes hard.
Posts: 2147 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:9880:1008:2) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1247574 posted 10/23/19 09:58 PM     Remind Me!  Send Private Message   Edit Post
I'm pretty sure that little strip does nothing to seal out any water, even when new.
-Mark
1051
Posts: 11939 | From: Yakima, WA | Member Since: 04/29/01 | IP: (47.42.152.133) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1247576 posted 10/24/19 06:35 AM     Remind Me!  Send Private Message   Edit Post
I'm with Wop. It's just to protect the glass from the metal. The seal is %100 on the backside of the glass. That area under the cowl is made to have water in it. It has a drain on both sides behind the fenders. The source of the dreaded fender rust after the drain holes clog up.
I love my crazy mother!!!
Posts: 1592 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
JR92
Newbie
104/1000
Galant VR-4 org Post #: 1247577 posted 10/24/19 11:18 AM     Remind Me!  Send Private Message   Edit Post
Ok. When I get it painted Iíll just put a strip of butyl tape on the underside. Iíll definitely check the drain holes to see if thatís the cause of the leak. Already tested the sunroof drain tubes and they are ok.
Posts: 18 | From: Woodbridge, Va | Member Since: 04/04/17 | IP: (2600:1:f1a6:6f5:) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1247582 posted 10/25/19 08:55 AM     Remind Me!  Send Private Message   Edit Post
You can see them here with the fender off. Both the large opening and the rubber dink.
JR92
Newbie
104/1000
Galant VR-4 org Post #: 1247593 posted 10/28/19 06:59 AM     Remind Me!  Send Private Message   Edit Post
Pulled the fender and checked. There was a little dirt in the forward hole but the rear one was clear and the sunroof drain was intact. The only thing that makes sense at this point is the windshield must be leaking. Going to take it by my local glass shop and get them to reinstall it.
Posts: 18 | From: Woodbridge, Va | Member Since: 04/04/17 | IP: (164.82.84.22) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1247595 posted 10/28/19 11:46 AM     Remind Me!  Send Private Message   Edit Post
Check the AC connections at the firewall. You can get a leak there too. Sometimes it gets pushed back inside a bit
Thom
Posts: 887 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (99.41.236.89) | Report this post to a Moderator
JR92
Newbie
104/1000
Galant VR-4 org Post #: 1247620 posted 10/31/19 11:24 AM     Remind Me!  Send Private Message   Edit Post
Didnít even think of that. I did notice when I removed my ac lines that the connector on the firewall was a little loose. I'll check it out.
Posts: 18 | From: Woodbridge, Va | Member Since: 04/04/17 | IP: (164.82.84.20) | Report this post to a Moderator
Generated in 0.243 seconds in which 0.225 seconds were spent on a total of 14 queries. Turbo powered.
