Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Gas tank studs
Gas tank studs
Blown1
Galant VR-4 org Post #: 993796 posted 05/18/11 05:35 AM     Remind Me!  Send Private Message   Edit Post
Hey guys just wondering if the studs that come up from the gas tank that comes thru to the sending unit are removable and replaceable? Tried to undo the fuel sender today ended up snapping two of the studs even after I soaked the bitch with pb blast etc. I need to change the 255's sock as I think it's clogged/dirty from years of crap in the fuel tank.Can I remove the broken studs and replace with new one's or am sol and need to drill them out and re-tap for bolts?Thanks again...
D.....
Edited by Blown1 (05/18/11 05:36 AM)
| | | IP: (71.235.196.54) | Report this post to a Moderator
Struc
Not all filled in
Galant VR-4 org Post #: 993827 posted 05/18/11 10:21 AM     Remind Me!  Send Private Message   Edit Post
You're pretty stuck. There isn't much material there to drill & tap for bolts either. Usually, the only alternative is self tapping sheet metal screws, or pull the tank and have the mounting ring replaced.
Curt Shambeau
92 GVR4 56/1000 (SOLD)
09 Lancer Ralliart (SOLD)
96 Spyder GS(t) (SOLD) - My 4G64 Spyder Website
1987 Montero SWB (Wideblock 4g64 build in progress)
Posts: 764 | From: Oconomowoc, WI | Member Since: 11/24/08 | IP: (174.102.163.51) | Report this post to a Moderator
donkeylips
Swapped Female Parts
924/1000
108/1000
372/1000
Galant VR-4 org Post #: 993852 posted 05/18/11 12:44 PM     Remind Me!  Send Private Message   Edit Post
I'm curious if anybody has had work done on their tank and how much it cost them. I've got 2 vr4s and a 3rd spare tank I wouldn't mind refurbishing.
1990 Nordic Blue Galant GSX, A71 KG 372/1000
A72 KG 108/1000 & A72 BG 924/1000 - Both Rotted
93 Mirage, 92 TealSI AWD, 85 200sx, 87 Trans Am
Posts: 552 | From: Rochester, NY | Member Since: 06/19/09 | IP: (74.74.141.199) | Report this post to a Moderator
Jesse_W
Galant VR-4 org Post #: 993856 posted 05/18/11 01:20 PM     Remind Me!  Send Private Message   Edit Post
I had the same problem, just drilled out all the studs or places for them and went to my local hardware store and bought Nuts and bolts. I have found out a better way to remove these nuts, oddly enough I use vice grips now, the last tank i did the nuts were bad enough that they looked like blobs of rust. Ended up getting them all off with out breaking 1 stud, easiest way i ever done. Done it on 3 tanks now and havnt lost a stud yet.
Jesse.
| | | IP: (66.76.18.251) | Report this post to a Moderator
Blown1
Galant VR-4 org Post #: 993890 posted 05/18/11 03:56 PM     Remind Me!  Send Private Message   Edit Post
Quoting donkeylips:
Wanna sell one of those tanks?
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 993908 posted 05/18/11 05:38 PM     Remind Me!  Send Private Message   Edit Post
Fuel tank stud replacement
tyler
2016 Explorer PI
2006 LS430
2012 GX460
Posts: 3855 | From: Cypress, TX | Member Since: 08/07/02 | IP: (76.30.185.53) | Report this post to a Moderator
Blown1
Galant VR-4 org Post #: 993923 posted 05/18/11 07:00 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the link, but I found a place in Pa that does gas tank restorations. I spoke to the owner and I will be dropping my tank shortly and shipping it off to them to be repaired and restored. Its way cheaper than a new tank and should be better than new when done. I am also going to add the sump feature for that little extra something.Here are the links below for the tank repair and restoration and also one for the sending unit wish me luck......
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.136 seconds in which 0.106 seconds were spent on a total of 14 queries. Turbo powered.
