Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Twin turbo when do they kick in???
pl4tnm
Galant VR-4 org Post #: 973629 posted 03/01/11 09:34 PM     Remind Me!  Send Private Message   Edit Post
sorry im really new to this. just bought a vr4 1997 galant TT and wondring if anyone knows wat rpm do the turbos kick in??
| | | IP: (118.92.157.221) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 973631 posted 03/01/11 09:52 PM     Remind Me!  Send Private Message   Edit Post
eleventy
-Mark
1051
Posts: 11965 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.5.156) | Report this post to a Moderator
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 973634 posted 03/01/11 09:59 PM     Remind Me!  Send Private Message   Edit Post
Um, I'm thinking you'd know when the turbos kick in by the boost gauge reporting 1psi or more.
You might want to check out ClubVR4.com, my Kiwi friend. 99% of the people here have the earlier VR4s. You know, the ones that look like Nissan Maximas with the four cylinders. :P
Brian | 98 Pajero | Gearbox Magazine
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (68.2.218.42) | Report this post to a Moderator
pl4tnm
Galant VR-4 org Post #: 973635 posted 03/01/11 10:03 PM     Remind Me!  Send Private Message   Edit Post
eleventy??? i feel the turbo kick in around 3 or 3.5'rpm? but this is twin turbo so im guessing there a problem somewea. either the primary or secondary turbo is not working.
pl4tnm
Galant VR-4 org Post #: 973636 posted 03/01/11 10:05 PM     Remind Me!  Send Private Message   Edit Post
sweet thanks, will check it out.
"Just to be pedantic!"
Galant VR-4 org Post #: 973686 posted 03/02/11 03:42 AM     Remind Me!  Send Private Message   Edit Post
the turbos aren't sequential (ie not primary and secondary), there are two turbos working in parallel - one turbo per bank of three cylinders given it's a V6 engine. The turbos are quite small, they are twin TD025 which is about 2/3rds the size of a TD04 on a 1.8L Lancer GSR Turbo. They should spool up just about instaneous from approx 2000rpm but will run out of puff towards 6000-6500rpm.
Posts: 2161 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.44.68) | Report this post to a Moderator
Galant VR-4 org Post #: 973690 posted 03/02/11 07:37 AM     Remind Me!  Send Private Message   Edit Post
Correct!
Mine were off and running hard by 2500 rpms. Power does drop off in the upper rev range but I never noticed it as low as 6500 rpms, my recollection could be hazy though as I got my turbos upgraded. I'm also not convinced that power falling off at higher rpms is really an issue unless you are going so fast you are battling serious drag and or going uphill. After you overcome inertia it takes less power to keep you moving. As a rule of thumb if the rpms are rising steadily and you don't have any slippage (clutch on it's way out or spinning tyres etc) you should still be accelerating fine. I guess more power just means you accelerate faster but unless you have built an engine capable of very high rpms, that rev limiter comes up very quick!
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (116.48.4.133) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 973704 posted 03/02/11 09:44 AM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
eleventy
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (65.125.130.49) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 973711 posted 03/02/11 10:24 AM     Remind Me!  Send Private Message   Edit Post
You made my morning wop...
Roger B. Scott
'91 Belize Green
Posts: 3313 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (174.45.93.14) | Report this post to a Moderator
Axeboy
Galant VR-4 org Post #: 973803 posted 03/02/11 04:42 PM     Remind Me!  Send Private Message   Edit Post
This might help. This was tuned a bit, but shows the general torque curve for my old Legnum. Peak boost was around 2250.
Edited by Axeboy (03/02/11 04:43 PM)
| | | IP: (78.105.185.244) | Report this post to a Moderator
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.064 seconds in which 0.051 seconds were spent on a total of 14 queries. Turbo powered.
