Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Alternator - B terminal spins when trying to remove nut
Dan D
220, 221... whatever it takes
410/2000
Galant VR-4 org Post #: 945909 posted 11/03/10 06:16 AM     Remind Me!  Send Private Message   Edit Post
I'm trying to remove the alternator. All is fine and good except I can't get the output cable off. The terminal itself is a stud with a hex section. This part fastens into the alternator. Then the cable lug slips over it and a nut goes on to secure. When I tried to loosen the nut, the whole terminal stud turns. This is a big problem because the cable goes with it since it is sandwiched in between the nut and terminal.
There isn't enough room to get any sort of wrench in my tool box onto the hex portion of the terminal stud to hold it still while I loosen the little 10mm nut. The terminal lug on the cable has a larger outside diameter than the hex portion and the alternator body guards it pretty well. Anyone had this happen? How did you stop the terminal from spinning to break the nut loose?
#410/2k
Posts: 1161 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (173.185.16.182) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 945923 posted 11/03/10 08:05 AM     Remind Me!  Send Private Message   Edit Post
Can you notch the stud with a dremel so that you could hold it from spinning with a flathead screwdriver while you loosen the nut?
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 945956 posted 11/03/10 10:25 AM     Remind Me!  Send Private Message   Edit Post
Are you trying this from above or below? If you have the fuel filter off, I think you may have a much better shot from below (if memory serves...).
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 945981 posted 11/03/10 11:31 AM     Remind Me!  Send Private Message   Edit Post
I thought the alternator sits by the OFH and the turbo assembly is pretty close to it. Well that is how it is on my car.
Easiest way I can think of is to just cut it very close to the connector and re-crimp on a new ring style crimp. The wire should have enough play to move 1-2 inches.
I can see why that heat shield is critical. I need to go make one.
1992 Galant VR4
1996 Toyota Supra TT
Edited by alansupra94 (11/03/10 11:33 AM)
Posts: 1909 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (173.3.24.20) | Report this post to a Moderator
Dan D
410/2000
Galant VR-4 org Post #: 946075 posted 11/03/10 04:01 PM     Remind Me!  Send Private Message   Edit Post
I hate to cut the wire, but that might be what I do. I was thinking that maybe the other option is to go ahead and remove the mounting hardware, free-up the cable from some of the tie-downs and rotate the now loose alternator around the stud until it comes out. Then I'll be able to use two wrenches to break the nut loose and put the stud back into the alterator.
It's always something. I should kick myself in the teeth every time I utter - this should be quick and simple! It jinxs me every time.
Posts: 1161 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (75.148.173.193) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 946079 posted 11/03/10 04:24 PM     Remind Me!  Send Private Message   Edit Post
Quoting alansupra94:
Whoops! I mean't "OIL" filter, not fuel filter.
-Jeff
1881/2000
50/1000
bazeng
work in progress
Galant VR-4 org Post #: 946111 posted 11/03/10 06:01 PM     Remind Me!  Send Private Message   Edit Post
I cut the wire, removed the alternator, held the alternator in a vice by the b terminal using alloy platesto keep the thread good and fit in a spanner to info the nut
Australia's Slowest VR4
Posts: 2520 | From: Melbourne, Australia | Member Since: 02/06/03 | IP: (110.23.55.91) | Report this post to a Moderator
Dan D
410/2000
Galant VR-4 org Post #: 946275 posted 11/04/10 05:52 AM     Remind Me!  Send Private Message   Edit Post
I got it! There's just enough exposed thread sticking out to wrap it with glass tape and use my smallest tiny needlenose vise grips to grab. I slipped a 10mm box wrench over the end onto the nut and then clamped on the vise grips to the taped portion of the exposed stud. A good hard squeeze and it let go. No messed up threads either. Gotta love glass tape.
After getting it loose and inspecting it, there's a nick in one of the wires so I'm going to have to cut it and crimp on a new terminal anyway. Oh well.
#410/2k
alansupra94
4/1000
Galant VR-4 org Post #: 946405 posted 11/04/10 01:28 PM     Remind Me!  Send Private Message   Edit Post
Quoting jepherz:
For a second, I was like...do I have a cool relocated alternator? Shot me down
1992 Galant VR4
1 registered and 21 anonymous users are browsing this forum.
Generated in 0.066 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
