Galant VR-4 Forums » Galant VR-4 » Technical Discussions » New Transmission Problem
Dan D
220, 221... whatever it takes
410/2000
Galant VR-4 org Post #: 894140 posted 04/28/10 04:50 PM     Remind Me!  Send Private Message   Edit Post
I had my transmission rebuilt by Jacks this past fall. I finally got around to installing it this past weekend. Got everything in, clutch bled, etc. and couldn’t get 5th or reverse. Ah! Shifter adjustment. Re-adjusted the cable ends. No luck .
I took the shifter cables off on the trans side and actuated the levers directly by hand. 1st to 4th are no problem. The select lever will go into the 5th/Rev position, but the shift lever won’t budge to select either gear.
After almost a year of being parked, I had to take my new engine’s first break in drive with no 5th or reverse . Any ideas on what to check without pulling the tranny back off. I’d like to rule out all possibilities before returning the car to JSB’ing status.
#410/2k
Posts: 1160 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (75.148.173.193) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 894149 posted 04/28/10 05:07 PM     Remind Me!  Send Private Message   Edit Post
Unscrew your reverse sensor and try it again. If it works, re-tighten your reverse sensor, but not as tight. You can also add additional crush washers under the sensor to space it out.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.185.58.90) | Report this post to a Moderator
Dan D
410/2000
Galant VR-4 org Post #: 894228 posted 04/28/10 09:22 PM     Remind Me!  Send Private Message   Edit Post
Ding Ding Ding!
You win. That seems to be the problem. With no sensor, 5 & reverse engage easily. I'll have to go get some washers now because even finger tight impeedes shifting.
Thanks for the help
#410/2k
Posts: 1160 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (98.20.79.122) | Report this post to a Moderator
BOOSTIN HARD
Galant VR-4 org Post #: 894234 posted 04/28/10 09:35 PM     Remind Me!  Send Private Message   Edit Post
Quoting BarnesMobile:
Very good advice Mr. Barnes.
And thank you Dan for telling us that fixed it.
| | | IP: (75.207.254.34) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 894276 posted 04/28/10 10:44 PM     Remind Me!  Send Private Message   Edit Post
I gotta pull my weight around here every once in a while right? Glad I could help.
-Jon Barnes
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (71.93.13.177) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 894437 posted 04/29/10 01:29 PM     Remind Me!  Send Private Message   Edit Post
damn it, I had been having this problem for a long time and everyone kept pointing towards the cables or a bad shift fork. Doesn't matter now though, as I'm just going to get the trans rebuilt.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2751 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (138.163.106.71) | Report this post to a Moderator
Generated in 0.092 seconds in which 0.078 seconds were spent on a total of 14 queries. Turbo powered.
