My bet is your brake pads are almost worn out. As your brake pads wear, the caliper pistons are extended more and more. This uses up more brake fluid, therefore the level in your brake fluid reservoir drops. The light indicts this low level.
So check to see how worn your brake pads are. If they aren't worn, you might have a bad connection to the e-brake sensor.
