Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Making progress on 192.
Boostdtalon
Member +++
Galant VR-4 org Post #: 880664 posted 03/09/10 06:45 PM     Remind Me!  Send Private Message   Edit Post
Well since the weather has finally improved. I took the opportunity to work on 192. After the issue witht the burnt harness; I bought the front end harness from NateCrisman (Big thanks btw) to replace the one that i suspected of being destroyed. Just taking my time things went pretty smoothly. I also took the time to do a couple of other things I've been needing to do such as swap out the non functional cruise control for the N/A throttle cable,remove a/c condensor and lines, and begin getting everything ready to relocate the battery back to the front of the car.
A little history: the PO before me put a radiator out of a neon in the car to make room for the holset he had in it. Well this radiator was not properly mounted by any means and was actually laying against the radiator support. One of the fans had been rigged to run when the ignition was in the on postion. Mind you nothing i've found so far had been done correctly or safely.
As I pulled the harness from the front of the car where it runs underneath the radiator support I saw this. The culprit behind why I had to replace the entire lighting and wiper assembly on the column and my headlights remained on at all times with the switch unplugged and fuses/relays removed .
As it stands right now I will be replacing the radiator. I have many options open to me and can not decide which way to go. The civic and AFCO radiator setup sounds nice for the space it gives. But I think a stock radiator would be nice too.
Posts: 913 | From: Buckley, Wa. | Member Since: 10/15/09 | IP: (75.191.135.38) | Report this post to a Moderator
Kid_eclypse
Galant VR-4 org Post #: 880882 posted 03/10/10 10:08 AM     Remind Me!  Send Private Message   Edit Post
wow that sucks about the harness but on the radiator u can use the VW scirocco it works great amd frees up alot of space
| | | IP: (76.17.22.161) | Report this post to a Moderator
687OF2000
Galant VR-4 org Post #: 880886 posted 03/10/10 10:12 AM     Remind Me!  Send Private Message   Edit Post
And I thought I had harness problems.
| | | IP: (70.190.64.88) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 880964 posted 03/10/10 02:55 PM     Remind Me!  Send Private Message   Edit Post
Thats what i'm leaning towards as far as the radiators go. Yeah harness issues suck.
Boostdtalon
Member +++
Galant VR-4 org Post #: 882823 posted 03/17/10 06:16 PM     Remind Me!  Send Private Message   Edit Post
well the head is at the machine shop awaiting parts.
Thank you Slowboy for making my bank account smaller.
parts list:
Gates timing belt kit
Manley springs and retainers
SI nitrite coated valves
cometic upper gasket kit and MLS headgasket
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 882941 posted 03/18/10 04:22 AM     Remind Me!  Send Private Message   Edit Post
hey let me know if you need help
565/2000
699/2000
Posts: 370 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (68.18.160.79) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 882949 posted 03/18/10 07:11 AM     Remind Me!  Send Private Message   Edit Post
Will do man. my biggest goal right now is to replace my radiator and install the wiring harness. gonna try and install it this weekend.
Posts: 913 | From: Buckley, Wa. | Member Since: 10/15/09 | IP: (207.4.213.11) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 882963 posted 03/18/10 08:58 AM     Remind Me!  Send Private Message   Edit Post
Gotta to take my dash out and get my cage started.
565/2000
699/2000
Boostdtalon
Member +++
Galant VR-4 org Post #: 882969 posted 03/18/10 09:18 AM     Remind Me!  Send Private Message   Edit Post
you still looking for a crank?
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 883048 posted 03/18/10 01:22 PM     Remind Me!  Send Private Message   Edit Post
yep
565/2000
699/2000
Boostdtalon
Member +++
Galant VR-4 org Post #: 883052 posted 03/18/10 01:27 PM     Remind Me!  Send Private Message   Edit Post
I got a used one. haven't had it checked out but if you want it lemme know. i'll work something out with ya.
Boostdtalon
Member +++
Galant VR-4 org Post #: 883584 posted 03/20/10 08:34 PM     Remind Me!  Send Private Message   Edit Post
got the new used harness installed. just a few things left to plug in and mount and its finished as far as the harness goes. gotta finish putting the battery terminals back together as well. i'll post some pics tomorrow after i get done working on it.
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 883589 posted 03/20/10 08:55 PM     Remind Me!  Send Private Message   Edit Post
cool get that G running
565/2000
699/2000
4orced4door Galant VR4.org Moderator
Out Standing
Galant VR-4 org Post #: 883590 posted 03/20/10 09:00 PM     Remind Me!  Send Private Message   Edit Post
I had an external dump o2 melt my harness like that. What a pain that was.
'17 GTI Sport, '02 V70
96/1000, 229/1000, 1788/2000... a long time ago
Posts: 9846 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (24.250.166.184) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 883591 posted 03/20/10 09:09 PM     Remind Me!  Send Private Message   Edit Post
yeah i'm about take the punishment O2 dump off this one and throw the stock one back in.
Boostdtalon
Member +++
Galant VR-4 org Post #: 884331 posted 03/23/10 09:41 PM     Remind Me!  Send Private Message   Edit Post
Well 90% of the parts have made it. Just waiting on the gasket kit right now. Dropped the head parts off at the machine shop. Found it'll be about $30 less than quoted.
Boostdtalon
Member +++
Galant VR-4 org Post #: 886405 posted 03/31/10 07:32 PM     Remind Me!  Send Private Message   Edit Post
got the radiator installed today. still got a few things to fab up and to put in. but everything is coming along. Had a good amount of wiring to fix since so much it had been hacked up by the PO.
Boostdtalon
Member +++
Galant VR-4 org Post #: 886944 posted 04/02/10 10:22 PM     Remind Me!  Send Private Message   Edit Post
well first i need to thank Curtis for all his advice and help! After talking with him since he was the one that made the brackets for the radiator. I moved some parts around and now the radiator sits about two inches forward, giving me even more room in the bay. I got the SPAL fan mounted with some custom brackets(after $60 worth of tools and parts). now to go browse the for sale ads as i'm in need of new positive and negative cables as mine were hacked to shit.
Boostdtalon
Member +++
Galant VR-4 org Post #: 888872 posted 04/09/10 10:55 AM     Remind Me!  Send Private Message   Edit Post
picked up new wheels yesterday. can't beat free.
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 888881 posted 04/09/10 11:16 AM     Remind Me!  Send Private Message   Edit Post
I'm a bit confused at what I'm looking at here.
A) Why is the engine bay side of the radiator covered with a piece of sheet metal? Is that to protect it when you are working in the engine bay?
B) Are the pusher fans as far away from the radiator as I think they are? It looks like they are almost 2" away from the actual radiator. Are you going to put the A/C condenser back in to take up that space?
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.185.58.90) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 888899 posted 04/09/10 12:36 PM     Remind Me!  Send Private Message   Edit Post
sorry for the confusion, i took the pics as i was test fitting everything. the plate on the back of the radiator was there to install a pull fan if i wanted to. I would have just need to cut an opening if i were to use it.i left it in place for the moment as to not damage the radiator as i was moving it quite a bit to get everything in place.
yeah they were about two inches from the radiator at first. but after removing the plate i moved the mounting bracket to the rear and this pushed the radiator further forward, so now the radiator sits just behind the fans. no i have no future plans to reinstall the AC.
Here are some better pics after i got everything mounted the way i wanted it.
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 889252 posted 04/10/10 10:50 PM     Remind Me!  Send Private Message   Edit Post
Wow nice work I am lovin the wheels
565/2000
699/2000
Posts: 370 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (75.183.112.168) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 889265 posted 04/10/10 11:37 PM     Remind Me!  Send Private Message   Edit Post
Thanks man. Maybe soon I can drive her down and make a visit with you and your 40!
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 889270 posted 04/11/10 12:23 AM     Remind Me!  Send Private Message   Edit Post
did you check out the pic's of the cage
565/2000
699/2000
Boostdtalon
Member +++
Galant VR-4 org Post #: 892078 posted 04/21/10 04:41 PM     Remind Me!  Send Private Message   Edit Post
Yeah I saw the pics. looks good!
This came in the mail today! Now to fix the battery cables and get new terminals. Hopefully be able to have 192 running by the end of this week. Might leave the battery facing that direction or flip it the other way.
Posts: 913 | From: Buckley, Wa. | Member Since: 10/15/09 | IP: (75.191.135.63) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 17 anonymous users are browsing this forum.
Generated in 0.084 seconds in which 0.054 seconds were spent on a total of 14 queries. Turbo powered.
