Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Oil leak. :(
Oil leak. :(
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 811889 posted 07/17/09 04:09 PM     Remind Me!  Send Private Message   Edit Post
I've had a small oil leak for some time, but lately I can't ignore it anymore. Is their a common place for oil leaks to start down low? I have oil getting on the driver side of the down pipe. I just jacked it up and let it run for about 10min, and I didn't see one new drop form. I'm guessing it only does it under boost or something. I have oil forming on the coolant line coming from the oil cooler/filter area. I just can't find a source.
I haven't checked today, but I've checked many times to make sure the t-belt was dry. It has always been bone dry. No oil on that.
Any ideals on where the oil could be coming from? This is driving me nuts. I can't drive 5 miles without smelling burning oil, but if I get under the car and wait, nothing. WTF?!?!?!?! If this helps, everything above the oil pan looks dry. I would think oil pan, but I'm just not finding the source.
1992 Nile black w/sunroof
Posts: 6007 | From: central Indiana | Member Since: 08/06/02 | IP: (68.58.11.188) | Report this post to a Moderator
Rock Star Status
Galant VR-4 org Post #: 811894 posted 07/17/09 04:39 PM     Remind Me!  Send Private Message   Edit Post
Turbo drain. My first guess.
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (63.253.227.122) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 811908 posted 07/17/09 04:56 PM     Remind Me!  Send Private Message   Edit Post
That's what I thought at first, but that is more on the right side of the down pipe and oil is leaking on the other side of it. I've seen others leak from that place and it's really obvious. Not one drop came from their.
I'm trying to find a local club member who has access to a lift. I suspect the car needs to be level, not on jack stands, and maybe even revved a little.
Or maybe I'll borrow my brothers set of jack stands, get it up on all 4 and level.
Is that oil dye good or BS? I've never used it, seen it used, but everyone talks about it.
Edited by gvr4ever (07/17/09 04:57 PM)
Muskrat
665/2000
Galant VR-4 org Post #: 811917 posted 07/17/09 05:26 PM     Remind Me!  Send Private Message   Edit Post
+1 for oil drain tube. That's where mine is leaking (got to remember to order the parts I need to fix that...)
If you're going to use the black-light dye have the underside of the car cleaned before adding it.
Brian L.
91 Galant VR-4 #665/2000
Posts: 2107 | From: Lexington, KY | Member Since: 06/13/04 | IP: (206.113.84.195) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 811919 posted 07/17/09 05:28 PM     Remind Me!  Send Private Message   Edit Post
Here are a few pics.
Most of the oil seems to be collecting on this short coolant hose. I replaced it a few months ago, cause the original one busted.
Oil return line doesn't seem to be the source. Maybe a tad wet, but no collected oil like other places.
Oil on the DP. I'm afraid this can catch fire.
Random engine pic because I had a camera in my hand.
Note, above the oil pan seems pretty dry. The valve cover gasket is new and dry. I really don't want to guess and replace the oil pan gasket, but I might have too. I hope I can find a true source this weekend.
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 811926 posted 07/17/09 05:36 PM     Remind Me!  Send Private Message   Edit Post
Could this be a case of the stock oil cooler crapola thing? While I still can't find a source, most of the oil seems to be collecting around that area.
Rock Star Status
Galant VR-4 org Post #: 811931 posted 07/17/09 05:54 PM     Remind Me!  Send Private Message   Edit Post
Is the oil return wet all the way up? If it's leaking under pressure (There should not be any pressure to speak of in the return), it'll throw the oil and collect in places where it can pool...
I'd be inclined to double check the turbo drain. Could also be a number of things, but this seems to the the most common. I'd also recommend cleaning the areas well, and firing it up/ taking it for a VERY short drive, and see what you find.
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (76.189.146.118) | Report this post to a Moderator
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 811935 posted 07/17/09 05:58 PM     Remind Me!  Send Private Message   Edit Post
Look up to the turbo end of the oil return line, it shouldn't get that wet (assuming it's in front of the leak when moving) that far up.
Check your dipstick tube, right by return line area.
Check the front of the lower timing cover to be sure it's dry (vs, something trickling down the outside of it)
I'm in a similar position, not as bad.. will do my oil pan (which has no gasket from factory) dipstick tube and return line all on next oil change just to eliminate sources
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (67.184.227.111) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 811936 posted 07/17/09 06:00 PM     Remind Me!  Send Private Message   Edit Post
I can try that tomorrow. The pictures didn't turn out so great, cause the camera didn't have enough light to focus. I'm just wondering of the drop of oil right behind the oil filter is a sign of the oil filter housing/cooler starting to fail. I know it's a problem and I never did go to the 90 style setup. Most of the oil seems to be coming from that area and spraying on the down pipe and that short coolant line has the most oil pooled up. Why it wouldn't leave one damn drop while I was watching it with the car running is beyond me.
Hard Snarker
1051/2000
Galant VR-4 org Post #: 811998 posted 07/17/09 08:24 PM     Remind Me!  Send Private Message   Edit Post
There is a seal within the oil cooler that may need to be replaced. It's pretty easy to do. Don't blame the oil cooler, there's nothing wrong with it. Shit just gets old.
If I were you, I'd put some cardboard under the front end while it's on jackstands and spray the whole underneath with brakeclean in an attempt to clean off all that residue. Oil creeps its way everywhere making it look like leaks are where they aren't. Then go for a drive and come back and have a look to see if any are forming to get a better idea of where they start.
Could be oil pan seal, turbo oil drain, oil cooler, any of the seals on the front of the motor like the crank and oil pump seal, cam seals, or even the valve cover gasket. If you let it go long enough that shit will seep all the way down to the bottom of the motor. Check the lower middle exhaust manifold stud as well since it threads into an oil drainback in the head and needs to be RTV'd when installed.
-Mark
1051
Posts: 11965 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
fivestardsm
"Savior of the damned and dis-owned"
Galant VR-4 org Post #: 812034 posted 07/17/09 10:13 PM     Remind Me!  Send Private Message   Edit Post
As turbowap said, the oil seal behind the cooler could be leaking, but...There is a problem that I have seen a BUNCH of times with these. If the oil filter gets over tightened, it will crush and deform the face of the cooler. When this happens, you will have a void where the oil seal seats, and the oil will leak out. The one thing that usually makes it worse, is people will try to tighten them up even more to get the leak to stop. All that does, is makes the leak bigger.
VR4 Picture Post
Steve.
. .27/1000 N B
.677/1000 S W
. .#?/2000 S W
.420/2000 B G
1361/2000 N B
1387/2000 N B
Edited by fivestardsm (07/17/09 10:14 PM)
Posts: 1699 | From: Middle, Michigan | Member Since: 09/08/06 | IP: (68.188.223.236) | Report this post to a Moderator
mooserage Galant VR4.org Administrator
New Title
254/2000
Galant VR-4 org Post #: 812036 posted 07/17/09 10:18 PM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
Oh snap! I just learned something, that's why it does that! Thanks
254/2000 Summit White
Posts: 1255 | From: Seattle, WA | Member Since: 05/17/04 | IP: (67.160.2.156) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 812401 posted 07/19/09 01:36 PM     Remind Me!  Send Private Message   Edit Post
It does appear to be the oil pan. Is there a gasket PN? Or do you guys just RTV it? Is the exhaust, t-case, long bracket, and oil return line the only thing in the way of removing it?
Also, while I'm working on it, I might just replace the oil cooler gasket too. Got a PN for that? Anyone have a write up?
Edited by gvr4ever (07/19/09 01:38 PM)
Hard Snarker
1051/2000
Galant VR-4 org Post #: 812407 posted 07/19/09 01:45 PM     Remind Me!  Send Private Message   Edit Post
Use ultra grey RTV to seal the pan. I don't know the part number for the oil cooler. It looks like an oil filter seal.
Sounds like you know what parts to remove to do the pan. Have at it.
-Mark
1051
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 812408 posted 07/19/09 01:48 PM     Remind Me!  Send Private Message   Edit Post
I figured I would just replace the oil cooler seal while I was working on it. Cause I will wait over night before adding oil anyway. Might as well knock out another possible leak. I foolishly drive my car out of state often.
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 812409 posted 07/19/09 01:50 PM     Remind Me!  Send Private Message   Edit Post
Oh real quick. Are the oil pan bolts different lengths? I seem to remember reading something about that.
Hard Snarker
1051/2000
Galant VR-4 org Post #: 812415 posted 07/19/09 02:21 PM     Remind Me!  Send Private Message   Edit Post
Just the two that sit underneath the timing belt. They're shorter. Just keep track of where they go when you pull them out.
-Mark
1051
Old Balls
425/1000
Galant VR-4 org Post #: 812435 posted 07/19/09 04:08 PM     Remind Me!  Send Private Message   Edit Post
I also have an issue with oil drips. I just got done cleaning the underside (again) and will inspect after a drive.
But I am sure my issue is the pan gasket. Next oil change it is coming off and I am going to just use Ultra-Grey and no gasket.
From what I have read, clean EVERYTHING with break cleaner and a rag, put a good bead of gasket RTV all the way around on the pan surface, let cure for 30 minutes and then assemble.
What a pain.
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.27.93.117) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 812438 posted 07/19/09 04:26 PM     Remind Me!  Send Private Message   Edit Post
I actually saw a wet spot form around the pan today after I cleaned some of the oil off. Ya, a PITA, but I've had many years of fun and now I gotta pay. More with labor this time then cost, but oh well. I think I can do it without sacrificing blood this time. I do think blood helps it run even better. Am I wrong?
Hard Snarker
1051/2000
Galant VR-4 org Post #: 812439 posted 07/19/09 04:26 PM     Remind Me!  Send Private Message   Edit Post
I always put the pan back on right after I ran a bead of RTV around it. I don't think it's necessary to wait.
-Mark
1051
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 812469 posted 07/19/09 07:09 PM     Remind Me!  Send Private Message   Edit Post
Anyone have the PNs for the oil return line gasket and crush washers? Anything else I need?
Galant VR-4 org Post #: 812646 posted 07/20/09 09:42 AM     Remind Me!  Send Private Message   Edit Post
Came across this today. I had seen the new gaskets with the sealer ring, but didn't know how to install them. This tells you the sealer side faces the oil pan side or turbo side when installed to the oil drain tube.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10840 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
fivestardsm
Galant VR-4 org Post #: 812864 posted 07/20/09 08:44 PM     Remind Me!  Send Private Message   Edit Post
Yeah the reson for the sealer toward the pan, is because it is more likely to be "un-true" because it is sheet metal, and the flange is thicker. I have installed a bunch of these and only used copper spray a gasket for sealent with out many problems. There have been a few that required silicone tho because of deflection on the pan surface.
VR4 Picture Post
Steve.
. .27/1000 N B
.677/1000 S W
. .#?/2000 S W
.420/2000 B G
1361/2000 N B
1387/2000 N B
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 813953 posted 07/23/09 04:48 PM     Remind Me!  Send Private Message   Edit Post
Wow, I'm like a dog that finally caught a car. I got all the oil pan bolts off (found and marked the two short ones) and now what? I can't think of too many things I hate more in life then a gasket that leaks, yet holds on for life.
Dave, I got the gaskets. Thank you very much.
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 814004 posted 07/23/09 07:42 PM     Remind Me!  Send Private Message   Edit Post
Okay, I cracked it off. I missed a bolt thought. Driver side axle needs to come off. I'll try and write a how to with some pics later.
Pages: 1 | 2
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.099 seconds in which 0.054 seconds were spent on a total of 14 queries. Turbo powered.
