Galant VR-4 Forums » Galant VR-4 » Technical Discussions » triangular black gusset plate.. leave it off?
RcBoost
Galant VR-4 org Post #: 660218 posted 06/22/08 03:28 PM     Remind Me!  Send Private Message   Edit Post
So im just wondering how many of you actually replace the gusset plate after installing your trans or new pass axle? Ive always replaced it on customers cars just because i would hate for something stupid to happen. I just dont see the point of putting it back on unless it does something significant.. Here at my home i dont have air tools so its a major pita to sit there and crank them out and in and i just had my trans off again and i figured id post this up to see how many of you run without the plate. I also attached a picture of it for refrance. Thanks in advance
| | | IP: (24.163.136.95) | Report this post to a Moderator
bustedsm
trying to feel really special
Galant VR-4 org Post #: 660224 posted 06/22/08 03:31 PM     Remind Me!  Send Private Message   Edit Post
Keep it! They were installed from the factory for a reason and are there so the subframe doesn't crack under load. Ask me how I know
2006 Kawasaki ZX-6R 636 - Raw Plasma Candy Blue
Posts: 844 | From: Ripley, Tennessee | Member Since: 11/30/06 | IP: (70.246.221.100) | Report this post to a Moderator
Bimmubishi
giant log
Galant VR-4 org Post #: 660267 posted 06/22/08 05:52 PM     Remind Me!  Send Private Message   Edit Post
It supports the control arm. Without it you could crack the subframe under hard use.
Posts: 5701 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (65.96.129.171) | Report this post to a Moderator
RcBoost
Galant VR-4 org Post #: 660268 posted 06/22/08 05:56 PM     Remind Me!  Send Private Message   Edit Post
sounds good lol i was looking while it was off and realized it looked like under a launch or something the subframe may try to flex without it. Thanks guys
belize1334
1334/2000
Galant VR-4 org Post #: 660269 posted 06/22/08 05:57 PM     Remind Me!  Send Private Message   Edit Post
The control arm takes it's hardest stresses under braking and cornering so that's where it would suffer most from lack of support. The only reason to leave it off would be weight gains and it's just not worth it for a few ounces.
Roger B. Scott
'91 Belize Green
Posts: 3312 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (76.105.206.7) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 660285 posted 06/22/08 07:00 PM     Remind Me!  Send Private Message   Edit Post
Myles had that problem. Had to have about 15" of welds to stitch his subframe back together.
VERY important.
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (12.210.169.170) | Report this post to a Moderator
14u2nV
Resident Pedobear
Galant VR-4 org Post #: 660293 posted 06/22/08 07:19 PM     Remind Me!  Send Private Message   Edit Post
:Mines been sitting on a shelf in my garage since I owned the car. When I got it, that piece along with the tranny was in the trunk, and I never had the correct bolts for it. Never had any issues.
~Kenneth Brian
"Censorship offends me" ~Author Unknown
Posts: 9397 | From: Agency/St. Joe, MO | Member Since: 07/22/04 | IP: (207.192.252.228) | Report this post to a Moderator
cOmpressor
also-ran member
Galant VR-4 org Post #: 660343 posted 06/22/08 09:26 PM     Remind Me!  Send Private Message   Edit Post
Obvously you don't drive hard core like Myles
"Life's too short to drive slow cars"
1992 Galant VR-4 KG Just taking a break
2005 Lexus IS300 Dropped but mostly stock
2014 Evo X MR Plastering a smile on my face daily
Posts: 2044 | From: Bay Area, CA | Member Since: 07/03/07 | IP: (76.103.213.121) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 660347 posted 06/22/08 09:33 PM     Remind Me!  Send Private Message   Edit Post
I think Myles put 30,000 miles on the car in his 1st year. He drove the piss out of it.
14u2nV
Resident Pedobear
Galant VR-4 org Post #: 660363 posted 06/22/08 10:17 PM     Remind Me!  Send Private Message   Edit Post
werd, mine spends a month on the road, then two in the garage, so-on and so-on.
~Kenneth Brian
RcBoost
Galant VR-4 org Post #: 660372 posted 06/22/08 10:25 PM     Remind Me!  Send Private Message   Edit Post
bah ive been really lucky so far that ive predicted each failing part on my car in the last month before they really rendered my car undrivable(kind of).. Replaced the trans, transfercase, & both front axles. The trans and the xfer both were not kept up on by previous owners so the fluids both came out as muddy trash a bit ago. Then a week later i drained and filled again only to find liquid metal city in BOTH fluids. Then the transfercase started getting REALLY loud and felt like trash so i replaced it and all was well. Then my 3rd gear decided to start grinding and somhow progressed into locking out, then blowing the center diff lol. While replacing the trans found both outer CV boots to be cracked wide open with rocks, dirt ect in there so i got some Raxles put in aswell and i should finally be good to go for a little bit. I am however very tempted to hit the track next friday to see what its got as it feels amazing at 27psi on E85 after my tuning on dsmlink lastweek. Im just VERY nervous that the next weak link will die (stock 3 bolt rear)...
bustedsm
Galant VR-4 org Post #: 660378 posted 06/22/08 10:34 PM     Remind Me!  Send Private Message   Edit Post
I got lucky and only found a tiny little crack forming and that all the holes lined up on the plate. Keep it
Posts: 844 | From: Ripley, Tennessee | Member Since: 11/30/06 | IP: (70.253.174.211) | Report this post to a Moderator
KT
Turbotoolbox
Galant VR-4 org Post #: 661104 posted 06/24/08 09:37 AM     Remind Me!  Send Private Message   Edit Post
When you remove all the bolts, throw them in a can of parts cleaner while you do the rest of the work. Before reinstalling them, hit them lightly with a wire brush or wire wheel to clean them up. Finally, some all purpose grease on the threads makes future removal a breeze.
I do this with all the hardware I remove while working on the car.
2016 Wrangler JKU
2012 VW Jetta TDI
2002 F-250 PSD
1999 LS7 C5
1988 Conquest TSi
Posts: 1243 | From: Omaha, NE | Member Since: 10/20/03 | IP: (75.65.65.230) | Report this post to a Moderator
SleepinGVR4
What are we going to do today Ferb?
629/2000
Galant VR-4 org Post #: 661248 posted 06/24/08 03:11 PM     Remind Me!  Send Private Message   Edit Post
I usually throw some anti seize on all the underbody braces. Also the DP bolts. ALways comes off when I need them too.
Sean
Posts: 2483 | From: Danville, Pennsylvania | Member Since: 02/12/03 | IP: (70.44.250.133) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 661272 posted 06/24/08 03:42 PM     Remind Me!  Send Private Message   Edit Post
Use the copper-based anti-seize for the downpipe bolts.
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.4) | Report this post to a Moderator
Myles
Douchebagel with Lox
Galant VR-4 org Post #: 661350 posted 06/24/08 05:34 PM     Remind Me!  Send Private Message   Edit Post
Quoting Terry Posten:
I don't know if amount of millage has anything to do with it. But that plate is very important definitely don't drive without it.
Quoting bustedsm:
+1 Ask me how I know. Or well just click
1929/2000 *SOLD*
Posts: 5264 | From: Skokie, IL | Member Since: 08/08/06 | IP: (207.229.152.234) | Report this post to a Moderator
1 registered and 10 anonymous users are browsing this forum.
Generated in 0.078 seconds in which 0.056 seconds were spent on a total of 14 queries. Turbo powered.
