Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Throttle Position Sensor
Galant VR-4 org Post #: 633033 posted 04/11/08 03:11 AM     Remind Me!  Send Private Message   Edit Post
How complicated are these? I have a 75mm throttle body that will eventually be going on the car. Wilson (who manufacture the TB) offer three TPS options from GM and FORD that are a direct fit to the TB.
What's my best bet? Re machining the throttle body so that the Mitsu TPS can be bolted up or can one of the above TPS options be spliced into the OEM wiring? I am using DSMLink so for the purposes of this question assume that we need to create a signal that works with a stock Mitsubishi ECU, not a standalone.
Link to the three TPS options
TPS options for 75mm TB
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (83.138.172.72) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 633042 posted 04/11/08 05:16 AM     Remind Me!  Send Private Message   Edit Post
The TPS is a varible resistor. Receives 5V and ground. The wiper arm sends a varying voltage to the ECU, depending on the position. The TPS varible resistance value is .22 Ohms to 4.9K ohms measured between ground and the arm. So any TPS that has 3 terminals with a fixed resistance of 4.7K to 5.0K ohms should work between the +5V and ground lines. I don't think this should be to hard to find.
Scott
525
Posts: 2054 | From: Norwell, MA | Member Since: 07/24/04 | IP: (71.232.40.49) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 633107 posted 04/11/08 10:22 AM     Remind Me!  Send Private Message   Edit Post
But, don't forget that some TPS's have an idle-closed switch integrated into them, which you *should* have, if possible.
| | | IP: (65.10.54.212) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 633110 posted 04/11/08 10:27 AM     Remind Me!  Send Private Message   Edit Post
Good point Jeff!
You will want an idle-closed switch. It would be nice if ours was incorporated into the TPS.
Scott
525
keydiver
Galant VR-4 org Post #: 633301 posted 04/11/08 07:55 PM     Remind Me!  Send Private Message   Edit Post
Just use a 2G throttlebody. I think they may be smaller in diameter though, but the TPS and idle-closed switch are integrated on a 2G throttlebody.
Galant VR-4 org Post #: 633397 posted 04/12/08 03:09 AM     Remind Me!  Send Private Message   Edit Post
Enlighten me please! What exactly does the idle closed switch do and if the switch is not integrated on the 1G, then where is it? What does it need to connect to? I need to work that out and doing any modifications preferably before fitting this TB.
keydiver
Galant VR-4 org Post #: 633422 posted 04/12/08 08:55 AM     Remind Me!  Send Private Message   Edit Post
The closed-idle switch on a 1G/GVR-4 is on the rear left side of the throttlebody, and simply shorts a wire to ground whenever the throttle is completely closed. It can cause a lot of idle surge issues if the ECU doesn't se it grounded.
1990/2000
Galant VR-4 org Post #: 633439 posted 04/12/08 10:35 AM     Remind Me!  Send Private Message   Edit Post
Quoting cheekychimp:
good thread
the bitterness of low quality remains long after the temporary joy of a low price has faded
Posts: 3540 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.14.71) | Report this post to a Moderator
Generated in 0.067 seconds in which 0.053 seconds were spent on a total of 14 queries. Turbo powered.
