Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Energy suspension master kit question
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 549998 posted 10/17/07 12:45 PM     Remind Me!  Send Private Message   Edit Post
I ordered a master kit for a 91 Mitsubishi Eclipse AWD from Energy Suspension Parts. According to their description shown here, they list "subframe" as part of the kit. Said part number is 54105 and contains 4 sleeves and 8 bushings and is meant to cover the 4 main points of the front subframe. That's it, no other bushings are in included for the rear subframe.
Unluckily enough, my rear bushings are what are really shot and in dire need of replacement. For those of you that have replaced these bushings or dealt with Energy Suspension, did you find the proper part from them or did you end up going elsewhere?
The arrogant bastard I dealt with on the phone basically spent 5 minutes telling me how I was wrong cause he didn't want to listen to what I was saying, then told me the only way to talk with their engineering department was to email them pics etc. which will probably take days for them to respond. Hopefully someone can chime in here.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.52) | Report this post to a Moderator
digit
Galant VR-4 org Post #: 550011 posted 10/17/07 01:14 PM     Remind Me!  Send Private Message   Edit Post
Does anyone even make poly bushings for the rear? I wasn't aware of any out on the market.... YET!
| | | IP: (24.110.105.216) | Report this post to a Moderator
turbogalant
Galant VR-4 org Post #: 550017 posted 10/17/07 01:32 PM     Remind Me!  Send Private Message   Edit Post
Includes:
- Front Control Arm Bushings
- Rear Control Arm Bushings
- Front Subframe Bushings
- Front 20mm Sway Bar and End Link Bushings
- Rear 20mm Sway Bar and End Link Bushings
- Tie Rod End Boots
| | | IP: (68.63.186.235) | Report this post to a Moderator
Polish
Dr. Pilosh Haagenscodyberger
Galant VR-4 org Post #: 550022 posted 10/17/07 01:41 PM     Remind Me!  Send Private Message   Edit Post
And the issue is the front sway bar is 21mm and the rear is 19mm. So the fronts go on REAL tight and the rears are a little loose unless you really tighten the clamp.
The front control arms bushings are good.
The rears are the control arms and trailing arms. I didn't put them in but they seemed good, I just sold the car before I got around to it.
If you read the Vfaq there was said to be some issue with the front subframe bushings but you could install them in place of another up front and it fit.
As for the rears, Shearer Fab makes some aluminum ones but they are VERY spendy. I think most just get a new OEM subframe with new bushings.
You can try Whiteline or Noltec for the subframe though, I am pretty sure one of them makes them. Although it's supposed to need shims depending on rust and such.
Here are 3 bushing threads I saved.
Bushing Post
Bushing Post
Bushing Post
All those should be archived imho.
My car site
Old GVR4 #1186/2000
Edited by Polish (10/17/07 01:42 PM)
Posts: 8936 | From: NE, IN | Member Since: 01/10/05 | IP: (69.245.199.104) | Report this post to a Moderator
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 550049 posted 10/17/07 02:24 PM     Remind Me!  Send Private Message   Edit Post
I am the process of getting poly bushing made for the rear subframe .
It will be a few weeks before its done.
I went thought the same problem with mine when i swap the subframe on galant.
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Posts: 4326 | From: Orlando, FL | Member Since: 04/24/03 | IP: (24.110.105.216) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 550053 posted 10/17/07 02:26 PM     Remind Me!  Send Private Message   Edit Post
Includes:
- Tie Rod End Boots
That change was actually just made to their website because of my questions on the subject. Before it just said "Subframe Bushings".
-Jeff
1881/2000
50/1000
digit
Galant VR-4 org Post #: 550057 posted 10/17/07 02:39 PM     Remind Me!  Send Private Message   Edit Post
Edited by digit (10/17/07 02:40 PM)
Polish
Galant VR-4 org Post #: 550065 posted 10/17/07 02:46 PM     Remind Me!  Send Private Message   Edit Post
Here are Shearers for $450 is anyone is curious.
My car site
Old GVR4 #1186/2000
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 550306 posted 10/17/07 11:26 PM     Remind Me!  Send Private Message   Edit Post
Anybody know where I can buy this "window weld" stuff? It's starting to sound like it may be my only option....
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (24.163.196.170) | Report this post to a Moderator
moonvan
Galant VR-4 org Post #: 550312 posted 10/17/07 11:47 PM     Remind Me!  Send Private Message   Edit Post
most auto parts stores, i used to use it for motor mounts
| | | IP: (67.183.194.10) | Report this post to a Moderator
turbogalant
Galant VR-4 org Post #: 550338 posted 10/18/07 02:21 AM     Remind Me!  Send Private Message   Edit Post
Napa
cOmpressor
also-ran member
Galant VR-4 org Post #: 550342 posted 10/18/07 03:12 AM     Remind Me!  Send Private Message   Edit Post
Ya any auto parts store near the adhesives.
"Life's too short to drive slow cars"
1992 Galant VR-4 KG Just taking a break
2005 Lexus IS300 Dropped but mostly stock
2014 Evo X MR Plastering a smile on my face daily
Posts: 2044 | From: Bay Area, CA | Member Since: 07/03/07 | IP: (75.18.181.107) | Report this post to a Moderator
Wizardawd
598/1000
Galant VR-4 org Post #: 550346 posted 10/18/07 03:32 AM     Remind Me!  Send Private Message   Edit Post
Usually runs about $10 per tube. Takes a while to set and cure too....
Question, I have a set of FWD front subframe poly bushings. If trimmed, can they work in the rear?
Wiz
598/1000 Nile Black
12/2000 Nile Black
1995 Montero SR
1997 Talon Tsi AWD Auto
Posts: 1323 | From: Franklin, NC | Member Since: 08/08/07 | IP: (192.28.2.41) | Report this post to a Moderator
Qship
Galant VR-4 org Post #: 550350 posted 10/18/07 04:09 AM     Remind Me!  Send Private Message   Edit Post
I would be very surprised if they did.
| | | IP: (24.21.152.15) | Report this post to a Moderator
Qship
Galant VR-4 org Post #: 550351 posted 10/18/07 04:12 AM     Remind Me!  Send Private Message   Edit Post
2nd post, 8 lines down
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 550353 posted 10/18/07 04:39 AM     Remind Me!  Send Private Message   Edit Post
How may people would be interested in these bushing for the sub frame.
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Posts: 4326 | From: Orlando, FL | Member Since: 04/24/03 | IP: (65.244.131.157) | Report this post to a Moderator
Oztek
Galant VR-4 org Post #: 550361 posted 10/18/07 05:45 AM     Remind Me!  Send Private Message   Edit Post
You'd probably have a bunch of people interested if the price was right.
BTW, Noltec is not producing the subframe bushing anymore. It's been discontinued.
| | | IP: (63.68.228.197) | Report this post to a Moderator
Wizardawd
598/1000
Galant VR-4 org Post #: 550369 posted 10/18/07 06:03 AM     Remind Me!  Send Private Message   Edit Post
Anyone know if this guy still makes his bushings?
Wiz
598/1000 Nile Black
12/2000 Nile Black
1995 Montero SR
475/1000
Galant VR-4 org Post #: 550399 posted 10/18/07 08:05 AM     Remind Me!  Send Private Message   Edit Post
Actually wiz these bushing above were what started this. John needs bushings. Paul had a set of these above from the dsm tuners thread that he carried in his suitcase to me. I then carried them to John. John was going to have a set made for himself but has desided that the polyurethane would be a much better route. I'm sure real race cars wouldn't mind the vib etc that the polyethelene delievers but John does and is having a mold made and doing all this to cover the mold process . That way he doesn't take a huge lick and everybody benefits. I just got him measurement so that the mustache brace bushings will get replaced at the same time. Doing my part to make Vr4's ride better everywhere.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (24.183.205.195) | Report this post to a Moderator
Wizardawd
598/1000
Galant VR-4 org Post #: 550411 posted 10/18/07 08:26 AM     Remind Me!  Send Private Message   Edit Post
Well....i'm rdy for everything they make. Money in hand.
My 4-bolt rear is cleaned and painted. Just want new bushings b4 it goes in.
Wiz
598/1000 Nile Black
12/2000 Nile Black
1995 Montero SR
Posts: 1323 | From: Franklin, NC | Member Since: 08/08/07 | IP: (24.220.213.177) | Report this post to a Moderator
RayH
561/1000
Galant VR-4 org Post #: 550524 posted 10/18/07 10:35 AM     Remind Me!  Send Private Message   Edit Post
Wiz
I bought the same bushings but haven't had a chance to install yet. Note that Paul found they go on the rear subframe and moustache brace and not part rear and part front subframe as the DSMtuners thread says. I tried contacting the guy who made them but never heard back.
Posts: 2701 | From: NJ | Member Since: 04/09/01 | IP: (167.211.65.80) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 551091 posted 10/19/07 11:38 AM     Remind Me!  Send Private Message   Edit Post
I just contacted Prothane, as they have a "subframe" kit as well for 1g's (Part # 13-102). They informed me that their kit also just includes the 4 bushings for the front subframe.
So, to clarify using what I have learned so far, nobody is making a rear subframe kit out of polyurethane. Looks like I may be giving window weld a chance...
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.51) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 551098 posted 10/19/07 11:41 AM     Remind Me!  Send Private Message   Edit Post
I would be depending on price. What are you planning to make them out of? Depending on the hardness of the material, they look like they may be pretty stiff. Are you planning on having some sort of metal sleeve as an insert?
-Jeff
1881/2000
50/1000
BKatter
Galant VR-4 org Post #: 551127 posted 10/19/07 12:10 PM     Remind Me!  Send Private Message   Edit Post
I would definately be interested in rear subframe bushings. Replacing the bushings is next on my list.
Also, which 4 bushings come in the front subframe kit? I see 6 mounting points here.
| | | IP: (63.230.19.33) | Report this post to a Moderator
spooling92vr4
Yeah Toast! * Now with JELLY!!!
829/1000
Galant VR-4 org Post #: 551720 posted 10/21/07 05:56 AM     Remind Me!  Send Private Message   Edit Post
the ES kit does come with the bushings for the rear subframe, i got the kit from RRE a few years back and never used it on my eclipse so i used it on the gvr4. I think i have one and a half laying around without the metal sleeve. I remember it having all the bushings except new ones for the mustache brace
92 vr4 belize green # 829/1000....NOW RUNS! still needs tuning
Posts: 2511 | From: long island, NY | Member Since: 06/07/05 | IP: (64.12.116.6) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.074 seconds in which 0.044 seconds were spent on a total of 14 queries. Turbo powered.
