Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 2G power steering set up on your GVR4
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442394 posted 02/10/07 06:32 PM     Remind Me!  Send Private Message   Edit Post
I've got a lot of 2g stuff laying around so tonight i decided to toss the 2g power steering pump etc on the car. I guess just for the sake of looking newer and to be a little different? I'm a ricer, i know.
so far i have, 2g exhaust manifold, o2 housing, 2g trans, 2g slave cylinder, 2g injector clips and now 2g power steering pump. lol.
-Joshua Adventure Driven Design
1991 Galant VR-4
1999 Montero "Goldi-Locker"
Posts: 5593 | From: Arizona | Member Since: 05/28/03 | IP: (67.177.179.249) | Report this post to a Moderator
LunarShadow
Galant VR-4 org Post #: 442501 posted 02/11/07 09:01 AM     Remind Me!  Send Private Message   Edit Post
Well, its all aluminum so it should be lighter.
| | | IP: (24.99.21.37) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 442533 posted 02/11/07 11:50 AM     Remind Me!  Send Private Message   Edit Post
do 2g's have that steering cut bullshit too?
86gt pte67gtq
galant vr4 1464 12.83 @ 106
05sti, 400whp
00 2.5rs, for sale
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (69.248.160.150) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442635 posted 02/11/07 06:58 PM     Remind Me!  Send Private Message   Edit Post
yeah, hence the sensor on the top of pump.
1991 Galant VR-4
gtluke
Fegbasket
Galant VR-4 org Post #: 442637 posted 02/11/07 07:00 PM     Remind Me!  Send Private Message   Edit Post
the sensor see's pressure and raises your idle.
the cutout is mechanical
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442687 posted 02/11/07 08:32 PM     Remind Me!  Send Private Message   Edit Post
interesting info
1991 Galant VR-4
tharaka
Galant VR-4 org Post #: 442721 posted 02/11/07 10:07 PM     Remind Me!  Send Private Message   Edit Post
steering cut?
| | | IP: (203.214.109.116) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442727 posted 02/11/07 11:10 PM     Remind Me!  Send Private Message   Edit Post
where as it reduces the effect of the power steering pump itself as speed either speed or RPM's is increased, i cant remember which it is but it's supposed to make the wheel feel heavier at higher speeds making the car feel more stable and at lower speeds allow the wheel to turn freely for easy parking lot manuevering
1991 Galant VR-4
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 442731 posted 02/11/07 11:26 PM     Remind Me!  Send Private Message   Edit Post
luke is speaking of the horrible PS cutout that occurs in racing situations mostly, where the pump cuts out causing extremely stiff steering for a second. I forgot what the cause was, but someone else could probably explain.
Posts: 2962 | From: ellensburg,wa | Member Since: 01/14/02 | IP: (66.191.6.133) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442739 posted 02/11/07 11:56 PM     Remind Me!  Send Private Message   Edit Post
found on the talon digest about a guys 95 DSM:
The PS pump contains a flow control valve which restricts pressure at high
RPM. It can be found by removing the hose connector at the top of the pump.
As the flow increases the valve closes and restricts pressure. The valve
is kept open by a spring. I simply inserted small washers until the spring
is fully compressed so the valve will never close.
I have been running my car for over a year now with no ill effects.
looks like i'll be cramming some washers in it tommorow
Wonder why i couldnt just simply remove the spring.. hmm
1991 Galant VR-4
gtluke
Fegbasket
Galant VR-4 org Post #: 442822 posted 02/12/07 09:21 AM     Remind Me!  Send Private Message   Edit Post
the p/s cut is a huge pain in the ass in an autocross or in the snow when you are revving the engine and trying to turn.
i guess i'll just shove washers in mine too.
i like the aluminum pump though, i'll keep my eyes open for one.
i wonder if the 2g alternator is just as big of a piece of crap as the 1g one?
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (208.216.127.110) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442831 posted 02/12/07 09:49 AM     Remind Me!  Send Private Message   Edit Post
Yup, alternator is just as big a POS as it is on the 1g's
if you need a 2g PS pump i've got another entire assembly. lol. Pump, both pulley's, bracket. The only thing wrong with it is that sensor has the pin broke off it.
1991 Galant VR-4
mj_rosenfeld
Galant VR-4 org Post #: 442842 posted 02/12/07 10:12 AM     Remind Me!  Send Private Message   Edit Post
I've experienced that at high RPM heading into a corner and it feels like the steering wheel is set in concrete. This occurs in both 1G and 2G and the spools are different, but the fix is the same. Pull out the spool valve and insert a ring about 1/8 inch long cut off some hard tubing you have sitting around. After doing this the problem never came back. I found the info by Googling "RPM power steering cut out" or something like that.
Mike R.
| | | IP: (64.0.248.227) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 442848 posted 02/12/07 10:36 AM     Remind Me!  Send Private Message   Edit Post
did this require tearing the pump apart?
1991 Galant VR-4
gtluke
Fegbasket
Galant VR-4 org Post #: 442861 posted 02/12/07 11:09 AM     Remind Me!  Send Private Message   Edit Post
nah, you can do it on the car. just take the nut, then the stud out of the top.
i've actually read into this already, just haven't done it yet.
plus my p/s pump is every so slightly weeping fluid.
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
Galant VR-4 org Post #: 442862 posted 02/12/07 11:14 AM     Remind Me!  Send Private Message   Edit Post
So detail this for us. What parts did you have to change? Bracket? Pulleys because it uses ribbed belt not a V-belt?
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10838 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
mj_rosenfeld
Galant VR-4 org Post #: 442897 posted 02/12/07 12:13 PM     Remind Me!  Send Private Message   Edit Post
I would think you could do it in the car. Since I wasn't sure how to dimension the ring and didn't want a lot of downtime while I screwed around with it I bought a used pump for $15 fixed the cutout on that one then swapped it in.
Mike R.
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 443129 posted 02/12/07 07:59 PM     Remind Me!  Send Private Message   Edit Post
need:
-2g inner water pump pulley to drive the power steering pump
-2g PS pump
-2g PS pump bracket
-2g belt .5 inches shorter than stock. I believe it's a 27in belt.
1991 Galant VR-4
OMFGeofffff
All I want is a dodgy
567/1000
Galant VR-4 org Post #: 443150 posted 02/12/07 08:33 PM     Remind Me!  Send Private Message   Edit Post
Edited by uh_oh_its_JEFF (02/28/07 08:47 PM)
Posts: 867 | From: Burnsville, MN | Member Since: 05/05/06 | IP: (68.190.157.24) | Report this post to a Moderator
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 443248 posted 02/13/07 04:46 AM     Remind Me!  Send Private Message   Edit Post
i wonder how much power gain will the the 2g one makes due to the fact its a rib belt ( v belt robs power )
its free hp
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Posts: 4326 | From: Orlando, FL | Member Since: 04/24/03 | IP: (65.244.131.157) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 443274 posted 02/13/07 07:26 AM     Remind Me!  Send Private Message   Edit Post
What happens if you were trying to turn while revving high then your power steering went out. Fried pump?
no, the mitsu design bypasses the pump at high rpm. it pretty much turns the pump off when it nears redline.
its not bad for the pump, just makes it hard to drive.
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
475/1000
Galant VR-4 org Post #: 444013 posted 02/14/07 04:55 PM     Remind Me!  Send Private Message   Edit Post
Damn you guys I can't get a break.... something else to address for me to mod. I do have a serpentine 2.5 subaru one in the garage that has a tank on top.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (24.159.50.110) | Report this post to a Moderator
turbogalant
Galant VR-4 org Post #: 444017 posted 02/14/07 05:07 PM     Remind Me!  Send Private Message   Edit Post
its free hp
Yes, but since the you need a different size belt and different pulleys you forgot to take pulley size into account. Now the pump maybe under-driven or over-driven, so he actually maybe losing HP, or gaining more HP than you'd expect.
| | | IP: (71.228.146.127) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 444068 posted 02/14/07 07:46 PM     Remind Me!  Send Private Message   Edit Post
i'll check the pulley size tomorrow you OCD freaks.
1991 Galant VR-4
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 753369 posted 02/02/09 02:42 PM     Remind Me!  Send Private Message   Edit Post
what if used in conjuction with a 2g underdrive pulley? definent gain then.
We didnt start the fire! Billy Joel:E39A expert
181/1000 half-a$$ rally-fart
1630/2000 Ballin!
1844/2000 unwillingly put in 'storage'
mirage turbo sold to a guy who will wreck it
2012 EVO, too bad its not a Mitsubishi
Posts: 1155 | From: west virginia | Member Since: 10/22/08 | IP: (71.182.37.73) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 11 anonymous users are browsing this forum.
Generated in 0.079 seconds in which 0.05 seconds were spent on a total of 14 queries. Turbo powered.
