Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Removing u-joint circlips
spoulson
0 people like this
Galant VR-4 org Post #: 380470 posted 09/09/06 10:39 PM     Remind Me!  Send Private Message   Edit Post
I'm doing the transfer case recall kit on my GVR4. I dropped the xfer case and have the driveshaft end laying on the ground. I sprayed some liquid wrench on the circlip, but it won't budge. I broke a couple ends of my circlip pliers (the removable tips) trying to remove. Are there any tricks to getting these out?
Shawn Poulson*
  ʇuɐlɐƃ ɐ suʍo ɹǝƃuol ou *
Posts: 2907 | From: Middletown, DE | Member Since: 02/05/03 | IP: (71.246.3.115) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 380471 posted 09/09/06 10:43 PM     Remind Me!  Send Private Message   Edit Post
Use something to pry them out as you grip them with the pliers. Does the kit comes with new clips? If not you may as well order some new ones.
Check out this vfaq link
Edited by Garfield Wright (09/09/06 10:46 PM)
| | | IP: (66.176.231.122) | Report this post to a Moderator
steelythefez
Galant VR-4 org Post #: 380475 posted 09/09/06 10:58 PM     Remind Me!  Send Private Message   Edit Post
think you meant this link http://www.plymouthlaser.com/dshaft.htm
| | | IP: (24.91.73.142) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 380476 posted 09/09/06 11:08 PM     Remind Me!  Send Private Message   Edit Post
Thanks Paul, that's the one.
TWEAKD4
Member ++
59/1000
Galant VR-4 org Post #: 380522 posted 09/10/06 06:58 AM     Remind Me!  Send Private Message   Edit Post
I just did this and mine were rusted badly. It is much easier to remove the driveshaft to replace the u joint. I first sprayed them with PB blaster and let it sit for at least a day. I then took a nail and put them in the holes of the circlips and hammered the nail as I pried it free. I usually breaks it free enough to use the pliers to take them the rest of the way out. Using a small screwdriver to pry them out.
Craig
12.926/106.34mph best ET Race/pump mix
13.206/109.21mph best trap 93/E85 and meth on slipping clutch
Posts: 605 | From: Fort Wayne, IN | Member Since: 03/24/02 | IP: (71.97.150.217) | Report this post to a Moderator
spoulson
0 people like this
Galant VR-4 org Post #: 380633 posted 09/10/06 06:01 PM     Remind Me!  Send Private Message   Edit Post
Thanks all, I'll attack it again next weekend and try those tips.
Shawn Poulson*
Posts: 2907 | From: Middletown, DE | Member Since: 02/05/03 | IP: (71.123.42.177) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 380659 posted 09/10/06 08:01 PM     Remind Me!  Send Private Message   Edit Post
I've had some luck with a hook style pick. I usually break the clip free/get one end to move a schoshe, and then put the pick tool thru it and pull towards the center, and then kind of unwind it from the groove.
Please wear safety glasses
Posts: 3540 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.14.1) | Report this post to a Moderator
turbogalant
Galant VR-4 org Post #: 380754 posted 09/11/06 01:54 AM     Remind Me!  Send Private Message   Edit Post
I PB blastered mine, along with taking the Autozone ball joint press I was using and *pressing* them with the clips still on. This takes as much tension as possible off them along with putting on force to break it free for rust. You may also want to use some heat.
| | | IP: (71.228.146.127) | Report this post to a Moderator
Mr_HYDE
Galant VR-4 org Post #: 380980 posted 09/11/06 02:46 PM     Remind Me!  Send Private Message   Edit Post
| | | IP: (71.14.70.176) | Report this post to a Moderator
Generated in 0.133 seconds in which 0.106 seconds were spent on a total of 14 queries. Turbo powered.
