Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Fuel injector connectors
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1244540 posted 11/07/18 03:41 PM     Remind Me!  Send Private Message   Edit Post
I remember seeing a connector that didn't have those wire retention clips but I forgot what car they were from. I think they just were a push tab/lock. Anyone remember?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (50.193.76.1) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1244543 posted 11/07/18 05:49 PM     Remind Me!  Send Private Message   Edit Post
2Gs had them...
Posts: 263 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
Galant VR-4 org Post #: 1244544 posted 11/08/18 07:15 AM     Remind Me!  Send Private Message   Edit Post
That's what I used to update both my GVR4s.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10745 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1244545 posted 11/08/18 11:20 AM     Remind Me!  Send Private Message   Edit Post
Dodge caravans, durangos, pick ups. also a bunch of Chryslers to. just go to the junk yard and walk around for a bit.
138/2000
152/1000
Posts: 3616 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1244546 posted 11/08/18 11:29 AM     Remind Me!  Send Private Message   Edit Post
I haven't done the conversion yet. Should have when I changed the injectors last.
1992 Nile black w/sunroof
Posts: 5929 | From: central Indiana | Member Since: 08/06/02 | IP: (69.174.132.35) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1244550 posted 11/08/18 02:09 PM     Remind Me!  Send Private Message   Edit Post
those are the same ones found on the dodges and chryslers
138/2000
152/1000
4Grim
I deliver.
1948/2000
Galant VR-4 org Post #: 1244551 posted 11/08/18 03:01 PM     Remind Me!  Send Private Message   Edit Post
7g 97-98 shared the same injector clips as the 2g's did.
91 GVR4 1948/2000
96 Galant 5sp DOHC 4G64T
2002 Montero Limited
1998 Montero "Winter Package"
Posts: 2474 | From: Orlando FL | Member Since: 09/30/04 | IP: (192.234.90.29) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1244556 posted 11/08/18 08:34 PM     Remind Me!  Send Private Message   Edit Post
I strongly suspect these are and having worked on Caravan's with these same injector connectors, Caravan injector connectors - quick release style.
Mine came from Ebay and had some portion lightly sanded so no one would know the OEM the came from. They were cheap, so I bought them right away because I wasn't aware of
the pick and pull yards in my area anymore (which were around unbeknownst to me just a 20 min drive away).
C53A 1 of the ~1500
Posts: 1621 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.135) | Report this post to a Moderator
bradrs
Galant VR-4 org Post #: 1244559 posted 11/08/18 11:56 PM     Remind Me!  Send Private Message   Edit Post
I've got them if you are interested in new ones:
These are a good match to the 2G ones found in 97-98. Mitsu only used these for a couple years before going back to the earlier style. I probably would use the earlier style connector if I was doing a harness, but I've had enough people ask about them that I sourced them.
Posts: 128 | From: Alta Loma, CA | Member Since: 02/01/14 | IP: (172.86.186.171) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1244560 posted 11/09/18 02:07 AM     Remind Me!  Send Private Message   Edit Post
Can you sell me 6 with pigtails?
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
Galant VR-4 org Post #: 1244561 posted 11/09/18 07:11 AM     Remind Me!  Send Private Message   Edit Post
I believe this was discussed on a old thread here, but if you are using the genuine Mitsu 2g type, you can de-pin the terminals from the 1g style and insert them in the 2g. No need to cut/splice etc in this case. The terminals don't seem to fit exactly the same, but well enough I have never had any connection issues or pin-push out.
Brad, do you know if they actually use different type pins from 1g--> 2g?
Eager Beaver
Galant VR-4 org Post #: 1244568 posted 11/09/18 08:32 PM     Remind Me!  Send Private Message   Edit Post
Quoting bradrs:
Mentioned your products just a day or two ago, to a guy trying to get his 1.5L Mitsu running - same 1G style connectors due to identical Denso connections.
He said he was wiggling his connectors and he got the car to fire, so I have him checking for the green death. Anyways, I try to send people towards your connectors whether direct or through the companies you supply.
Thanks for popping in Brad!
C53A 1 of the ~1500
bradrs
Galant VR-4 org Post #: 1244570 posted 11/09/18 08:59 PM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
They are not the same terminals between the 1G and late 2G style connectors, the connectors are not even from the same manufacturer. Whether or not you can use them, I don't know.
Spoolinup was selling another squeeze type connector that was similar to the 2G, but not the same. You could use the 1G terminals in that. And I think it was a cheaper option.
I've seen the downsides of using the wrong terminal in a connector. Improper terminal retention, poor contact with the mating connector, etc. I would be wary of doing that, but I am sure Spoolinup has done some real world testing on this before saying it is OK.
Before doing that, I'd consider using the 1G connectors, and making a quick release connector somewhere else inline.
Edit: I think the pic that Flying Eagle posted, shows the Spoolinup type of quick release injector connector. It is slightly different than the 2G.
Edited by bradrs (11/10/18 12:02 AM)
bradrs
Galant VR-4 org Post #: 1244576 posted 11/09/18 11:57 PM     Remind Me!  Send Private Message   Edit Post
Quoting G:
I don't have pigtails for those available right now, sorry. But I do sell the connectors in sets of 6 for the 3000GT crowd, that is on the website.
Quoting FlyingEagle:
Thanks, Glad to help where I can.
JDM Unit
486/1000
Galant VR-4 org Post #: 1244578 posted 11/10/18 09:51 AM     Remind Me!  Send Private Message   Edit Post
I just found some in my stash. I thought I had bought some new ones with pigtails years ago but couldn't remember. Perfect fit for a gt-r.
www.nostalgic.co.jp
bradrs
Galant VR-4 org Post #: 1244586 posted 11/10/18 11:45 PM     Remind Me!  Send Private Message   Edit Post
What year GT-R? Must be an older one, because that type of injector connector with the rubber boot extending off the back is a really old design.
JDM Unit
486/1000
Galant VR-4 org Post #: 1244587 posted 11/10/18 11:59 PM     Remind Me!  Send Private Message   Edit Post
r32.
www.nostalgic.co.jp
0 registered and 40 anonymous users are browsing this forum.
Generated in 0.099 seconds in which 0.068 seconds were spent on a total of 14 queries. Turbo powered.
