Galant VR-4 Forums » Galant VR-4 » Technical Discussions » What coil-over setups are you guys running?
arapp
Newbie
865/2000
Galant VR-4 org Post #: 1240037 posted 10/21/17 05:01 PM     Remind Me!  Send Private Message   Edit Post
Just a survey to see what everyones running and what people like:
What coil-over setups are you guys running, especially those with the 245+ width tires?
Posts: 17 | From: So Cal | Member Since: 05/05/13 | IP: (47.150.21.125) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1240040 posted 10/21/17 07:47 PM     Remind Me!  Send Private Message   Edit Post
bc's came on 747 when i bought it
happy with them overall
Posts: 43 | From: Baltimore, md | Member Since: 04/18/16 | IP: (96.234.157.155) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1240047 posted 10/22/17 09:38 AM     Remind Me!  Send Private Message   Edit Post
i have a set of 1G Megan's with GVR4 specific k-sport top hats. i def like them a lot, just like every other coilover it just takes time to dial the suspension in. i think because these are meant for a DSM it took me a little longer then i would have liked to get the pre-load correct. i made about 7 or 8 pre-load adjustments before i got something comfortable out of them, ride height however was a breeze.
138/2000
152/1000
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
arapp
Newbie
865/2000
Galant VR-4 org Post #: 1240049 posted 10/22/17 05:17 PM     Remind Me!  Send Private Message   Edit Post
What are the k-sport specific top hats for the GVR4? Did the 1G Megan Racing Coil over top hats not work or are you running a different spring?
Posts: 17 | From: So Cal | Member Since: 05/05/13 | IP: (2600:1700:d3b0:d) | Report this post to a Moderator
Galant VR-4 org Post #: 1240055 posted 10/22/17 08:36 PM     Remind Me!  Send Private Message   Edit Post
1G has a different strut top mounting bolt pattern than the GVR4.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10857 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
diambo4life
Member +
476/2000
Galant VR-4 org Post #: 1240066 posted 10/23/17 09:43 AM     Remind Me!  Send Private Message   Edit Post
I have D2. Street version. Very happy with them.
1991 Belize Green GVR4 #476/2000: 788WHP/588wTQ (dynojet) Old setup, 3400lbs
Posts: 250 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (68.97.83.160) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1240072 posted 10/23/17 11:01 AM     Remind Me!  Send Private Message   Edit Post
Quoting arapp:
as Iceman said its just a different pattern. no i did not change out the springs. i changed the tophats because i got a killer deal on the megans and the k-sports that i had were blown out and rusted so badly i couldn't pull them apart completely.
I really liked my K-sports as well. i bought them used from a member on here(everything was pre-dialed in) who had went to the FEAL coilovers.
138/2000
152/1000
Edited by transparentdsm (10/23/17 11:04 AM)
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1240090 posted 10/23/17 08:00 PM     Remind Me!  Send Private Message   Edit Post
I have an old set of Muellerized JICs. I just had them refreshed last spring by JIC USA in Cali. So far so good.
-Mark
1051
Posts: 11967 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.4.116) | Report this post to a Moderator
gaylantvr4
Joe
Galant VR-4 org Post #: 1240094 posted 10/23/17 08:42 PM     Remind Me!  Send Private Message   Edit Post
jrz rs one coilovers
998/1000
Posts: 850 | From: Omaha ,NE | Member Since: 10/03/04 | IP: (68.13.39.198) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1240106 posted 10/24/17 08:55 AM     Remind Me!  Send Private Message   Edit Post
Feal long travel version. A little too much rebound in the rear for my liking. Fronts feel great though.
I am supposed to do a write up on them, but every time I choose to rallyx the car, I have some life event come up. It has been a year of just dd abuse. I refuse to slow down for speed bumps now and it feels great on gravel and rough roads, but like I said there is too much rebound in the rear even on the softest setting.
Posts: 429 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:6) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1240108 posted 10/24/17 10:39 AM     Remind Me!  Send Private Message   Edit Post
I am using Robispec'd KW V3's with Cusco front pillow ball mounts
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 800 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
MuffinMan7580
570/1000
Galant VR-4 org Post #: 1240342 posted 11/04/17 12:12 PM     Remind Me!  Send Private Message   Edit Post
Hot Bits are on 570. They're perfectly fine for me, as they give the car a very stable feel. I wish I had more to compare them to, but I don't. Only issue I have with them is that they are noisy with the solid pillow ball mounts up top, but you only hear them when you're driving on crappy roads. I'm running 205 tires with no rubbing at near stock ride height.
'92 GVR4 #570/1000
Edited by MuffinMan7580 (11/04/17 12:14 PM)
Posts: 142 | From: Fort Bragg, NC | Member Since: 08/06/11 | IP: (2600:6c51:6580:2) | Report this post to a Moderator
vr4play
handles best on 3 tires
816/1000
Galant VR-4 org Post #: 1240405 posted 11/07/17 06:42 PM     Remind Me!  Send Private Message   Edit Post
I had some custom fronts done for me. They use Koni 8611 double adjustable race inserts in a custom machined housing with BC lower mounts. I am using a custom valved set of 2g Eclipse rear shocks with Ground Control collars in the rear.
816 of 1000
[email protected]
??? of 2000
[email protected] on 93oct
[email protected] on C16
[email protected] on E90
ASE Certified Master Technician
www.Performance-Alignment.com
Posts: 397 | From: Cincinnati, Ohio | Member Since: 02/07/08 | IP: (2605:a000:c64f:9) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1240409 posted 11/08/17 03:03 AM     Remind Me!  Send Private Message   Edit Post
I have a set of D2s. With a finger and half wheel gap, mild spring tension, and a dampening setting that isnít too aggressive or stiff, theyíre alright. The winter time kills the roads in Nebraska so some spots feel bouncy at times but not too rough. Iíve ridden in cars with violently stiff suspensions and was not a fan. I believe thereís a balance as to what is feasible.
Edit: ***No body roll***
1099/2000 Summit white
"Do it once, Do it right."
Edited by Nebraska (11/08/17 03:08 AM)
Posts: 131 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.054 seconds in which 0.037 seconds were spent on a total of 14 queries. Turbo powered.
