Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 1991 Radio - Rebuild and install.
misterfixit
Victory Runner
Galant VR-4 org Post #: 1234729 posted 01/09/17 04:00 PM     Remind Me!  Send Private Message   Edit Post
Hi Folks,
Another one of those lovely long, lazy, multi cup of tea sagas.. I have for literally years be waiting to do this.
I finally found a 1991 head unit setup for PRU. It was sourced from the US, originally from a Dodge Stealth. I didn't pay alot (Happy me).
Those who know me, know I like taking stuff apart (and fettling things).
So stealth radio had some issues, and at least one key benefit!
Issues:
1. Won't play CDs
2. Lights up orange.
3. Filthy.
4. Has a clock I couldn't work out built in. (See Benefit)
5, All large caps made by rubycon!
Benefit's
1, UK compatible tuner. Gets all UK stations (No Band expander was needed)
2, Dimmable (Stock galant one is not I believe)
3, Clock built in once I'd worked it out
So To use these radio's you have to have the amp too. Luckily I'd had this a while:
There's not so many pics, but here are the main ones with it in bits. I'll start with the CD Player. Mitsubishi make so many versions with so many laser combinations, but this one was suitably old school and built like a truck.
You need to be ultra careful taking these apart for two reasons. One the flexi cables are so fragile. 2 the plastic parts are very old and brittle.
This monster flexi connects to the bottom of the CD assembly. I had a list of tasks as I took the old girl apart.
Here's the control board with the faceplate off.
This is a buttock clenching operation as you pull the screws out, then pry the board forward and unhook the bulb holders in the gap. Make sure you use PATIENCE here, you'll only get one go to get it right...
So as the unit was stripped I cleaned everything I could with cotton buds and ethyl alcahol (Make sure it's not the scented kind, that contains oils)
and looked over all the boards. I then changed all the bulbs as a few were blown. I then swapped the silicone covers on the lights to green (to match the car)
The CD module is an impressive piece of mechanical jewelery, so it got similar careful treatment, but I took time to work on the loading mechanism and the CD handling area to clean the filth off.
I don't know what had happened, but everything was very thinly veiled in a layer of blach particulate sludge.
You can then very carefully use soaked cotton buds to polish the cd lens.. now I wasn't sure how this would come out.. but the lens as you can see has a twinkle again here.
Now just put it all back together again...
Allpar has a nice set of pages taking a similar headunit setup apart,so this was very helpful to have in the back of my mind.
I took the headunit apart for the same treatment, but went a little further here:
Now when I put it all back together in the car I couldn't for the life of me work out why it was as dim as 1/2 candlepower bulb looked at through a winter sock.
I looked at the service manuals an nothing gave me any light until I sav the silk screen printing on the power board that said ILL-, then I traced out the circuit and got this:
The stealth had got a dimmable radio!
The galant dims the dash lights by varying the resistance to earth, so the feed is always 12v, but the earth connection goes off through the Rheostat. So I populated the spare earth connection, and connected him up in the car loom correctly.
Once this was done I was so happy to have the radio loom back to factory.
I took the amp apart and fixed the bad caps here too.. it smelt fishy.
There's alot of cans in there.. but the board is simple, not as fragile as the ecu one.
Luckily when I stripped a complete JDM car many years ago I had the complete set of the slave cables for the amp, so i removed the interior and laid these correctly up to the trunk, at this point the amp is just loose in the main luggage bay as I don't have the two pressed steel brackets to mount the amp to the trunk trim support (;) wink wink if anybody has a set to donate!).
When it all went back together it looked like this..
I like this head unit, it matches the climate control perfectly.
Now it's all back together it plays burned disks, provided they are burned slow enough, and it works well and sounds good, it tells the time too!
Sometime later I'd like to extract some line out signals to run the sub, but that's a project for another set of evenings...
Enjoy,
Rich
Posts: 1553 | From: Midlands, UK | Member Since: 08/04/04 | IP: (31.185.166.162) | Report this post to a Moderator
Galant VR-4 org Post #: 1234730 posted 01/09/17 04:15 PM     Remind Me!  Send Private Message   Edit Post
I may have some brackets for the amp, as I had a few bad 91 amps collected in the past.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10768 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1234734 posted 01/09/17 05:14 PM     Remind Me!  Send Private Message   Edit Post
Does the Stealth radio tune into even FM frequencies? I noticed some/most US radios only tune into odd FM frequencies - ie x.3 x.5 x.7 and not x.2 x.4 x.6 etc.
I want to find a stock early 90s looking Mitsubishi radio that has AUX input, line output and single DIN so I keep using the pocket below the radio.
Posts: 2151 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (180.181.213.100) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1234745 posted 01/09/17 10:55 PM     Remind Me!  Send Private Message   Edit Post
I'm guessing the brackets need to come from a galant and not a 3000gt/stealth? only a few base model galants around here but plenty of the 3si cars. I can be on the lookout next time I go JY hunting.
89 SWB Montero V6/manual (for sale)
95 Eagle Summit DL coupe
15 Mitsubishi Mirage ES hatch
Posts: 2501 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (76.6.142.114) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 1234749 posted 01/10/17 06:39 AM     Remind Me!  Send Private Message   Edit Post
Yes please! If anyone has a set that'd be great.
They do need to be from a galant. on the 3s cars the amp sits under the radio.
Fuel. I noticed the frequency divisions are a little odd, but it picks up the stations just fine.
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1553 | From: Midlands, UK | Member Since: 08/04/04 | IP: (195.33.118.208) | Report this post to a Moderator
Galant VR-4 org Post #: 1234750 posted 01/10/17 08:28 AM     Remind Me!  Send Private Message   Edit Post
Quoting fuel:
Not sure if I remember any 1-DIN units that had an Aux jack. Most of the 2-DIN units I have seen did (with the equalizer lower, cassette upper).
Gtpdz
594/1000
Galant VR-4 org Post #: 1234758 posted 01/10/17 04:00 PM     Remind Me!  Send Private Message   Edit Post
Only 2 DIN comes with aux jack, there's actually two kinds of them, I think one of which is the MB649778. They both look the same except one is 2 plug the other is 1 plug.
I have one that is 2 plug, it has some issues, cassette won't play, one channel is dead, volume encoder is bad, etc...
After that I found a 93 2 plug 1 DIN, and managed to fit a Bluetooth receiver in to replace the dead cassette unit, while maintaining the factory look from the outside and working radio and everything, will do a write up on this sometime.
Edited by Gtpdz (01/10/17 04:03 PM)
Posts: 140 | From: Gig Harbor, WA | Member Since: 03/12/15 | IP: (50.181.188.102) | Report this post to a Moderator
2 registered and 68 anonymous users are browsing this forum.
Generated in 0.098 seconds in which 0.056 seconds were spent on a total of 14 queries. Turbo powered.
