Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Front wheel bearing race stuck in Hub
tsitalon1
Member +
Galant VR-4 org Post #: 1200138 posted 01/29/15 09:37 PM     Remind Me!  Send Private Message   Edit Post
Need a bit of help guys.
I've done DSM wheel bearings before, but never had this problem...
Front bearing race is stuck in hub and my 12ton Harbor freight press is flexing and making me uncomfortable (even after tried torching it with a map gas torch)trying to push it out. I'm having difficulty getting the hub to sit flat on the press.
Tomorrow I plan to heat the hub up in the oven at 400 and then use dry ice on the race to see if I can loosen it that way.
In case your wondering my local machine shop refused the work stating "these are a pain in the ass".
Any other ideas?
Posts: 309 | From: Montgomery Al | Member Since: 12/29/10 | IP: (104.8.200.52) | Report this post to a Moderator
andrew4g63
GVR4 have DSM stickers all over them, they are DSMs
1706/2000
Galant VR-4 org Post #: 1200139 posted 01/29/15 09:49 PM     Remind Me!  Send Private Message   Edit Post
I never had this problem with a galant but I do have this happen at work all the time with Ford Explorer rear wheel bearings.
I use the oxygen and Acetylene torch to cut a slit in race and the race falls out normally. It's the only thing I've found tgat doesn't get hairy
Or take very long.
1706/2000 Hangs out in a corner of the garage
1702/2000 Daily Duties
1185/2000 wannabe rally car
46/1000 going back together
41/1000 Parts car
5/1000 Fixed-Sold!
Posts: 182 | From: Lake Geneva, WI | Member Since: 03/09/06 | IP: (166.181.3.8) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1200141 posted 01/29/15 10:45 PM     Remind Me!  Send Private Message   Edit Post
Another couple ways, either cut a slit in the race with a cut off tool and then a metal chisel to split the race, or cut two slots about halfway into and halfway up the race, to allow a bearing splitter to be locked into the slots then use an H-bar to pull it off.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.15.96) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1200152 posted 01/30/15 07:37 AM     Remind Me!  Send Private Message   Edit Post
Kinda confusing here, to me at least. Are you saying the outer race is stuck inside of the knuckle? Or are you saying the inner race won't come off the hub like the guys above are talking about?
93 Mitsubishi Expo LRV
95 Eagle Summit DL coupe
98 Mitsubishi Mirage DE coupe
Posts: 2502 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (184.3.237.217) | Report this post to a Moderator
Coltsfan
631/1000
Galant VR-4 org Post #: 1200157 posted 01/30/15 08:56 AM     Remind Me!  Send Private Message   Edit Post
He's going to put put dry ice on the race (shrinking it) so he must mean the race is stuck in the knuckle.
I personally (and this works with rear Explorer bearings too) put the knuckle on a large block of wood, and use the appropriate diameter drift to pound the race out with a four foot long sledge hammer. It always works, no matter what.
92 Galant Vr4 631/1000 ---------DD well on it's way to having new everything...
90 AWD Colt Hatchback ----------Fun car
51 Buick Special ---------------Boring car
Posts: 200 | From: Tonawanda | Member Since: 05/04/14 | IP: (76.180.21.67) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1200160 posted 01/30/15 09:16 AM     Remind Me!  Send Private Message   Edit Post
That's kinda what I was thinking too Dayo.
To the OP, I know you said you've done this before and this is probably silly but you did remove the huge circlip correct?
Coltsfan
631/1000
Galant VR-4 org Post #: 1200167 posted 01/30/15 09:57 AM     Remind Me!  Send Private Message   Edit Post
Good call on the clip Chris. It may be stating the obvious, but you just never know sometimes.
tsitalon1
Member +
Galant VR-4 org Post #: 1200172 posted 01/30/15 11:30 AM     Remind Me!  Send Private Message   Edit Post
Quoting 89Mirageman:
I'm sorry, I should have been more clear - It's the outter race stuck in the knuckle itself.
Edited by tsitalon1 (01/30/15 11:51 AM)
Posts: 309 | From: Montgomery Al | Member Since: 12/29/10 | IP: (158.15.255.228) | Report this post to a Moderator
tsitalon1
Member +
Galant VR-4 org Post #: 1200173 posted 01/30/15 11:32 AM     Remind Me!  Send Private Message   Edit Post
Absoluetely sir!
715/1000
1284/2000
Galant VR-4 org Post #: 1200177 posted 01/30/15 12:01 PM     Remind Me!  Send Private Message   Edit Post
Can you leave it for a couple of days? It's rust between the knuckle and outer race. If you can leave it, let it soak in WD-40 for a few days.
Also for freezing it, don't use dry ice. It works, but a can of compressed air turned upside down will work faster.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
tsitalon1
Member +
Galant VR-4 org Post #: 1200178 posted 01/30/15 12:31 PM     Remind Me!  Send Private Message   Edit Post
So the plan is to heat the knuckle in the oven at 400 and then freeze the race, does that still sound like a valid plan?
715/1000
1284/2000
Galant VR-4 org Post #: 1200181 posted 01/30/15 12:46 PM     Remind Me!  Send Private Message   Edit Post
It does. Your attempting to shock the rust that's bonding the two surfaces together. Snap-ring is out right?
Also, you are pressing the bearing out of the front of the knuckle right? The side facing the spindle?
Stupid questions, but just checking.
I usually (and this is VERY dangerous) is set-up the press and apply all the pressure I can, then use the torch to heat the knuckle. Its worked every time so far.
12yr+ Vr4 owner.
Family Guy
tsitalon1
Member +
Galant VR-4 org Post #: 1200183 posted 01/30/15 12:51 PM     Remind Me!  Send Private Message   Edit Post
Yep , snap ring is out and I'm pushing towards the snap ring side.
I"m not real comfortable with the current setup on the press using wrenches under it to level it, but I haven't found a better way yet. I'm nervous the wrenches are going to fly out
Maybe I'll heat/freeze and hit with 4lb baby sledge on the ground first
715/1000
1284/2000
Galant VR-4 org Post #: 1200187 posted 01/30/15 01:31 PM     Remind Me!  Send Private Message   Edit Post
If its as bad as it sounds, i doubt the sledge will help. All else fails take it to a mitsu dealer and ask nicely if they could pop it out.
Yea the wrenches are sketchy. I've used 1" rect tubing to level when pressing.
12yr+ Vr4 owner.
Family Guy
tsitalon1
Member +
Galant VR-4 org Post #: 1200221 posted 01/30/15 07:40 PM     Remind Me!  Send Private Message   Edit Post
Got it!
400 in the oven for 45min...and then used a can of compressed air to freeze the race and press it out....took 5 mins or less
Thanks for the help guys!
Posts: 309 | From: Montgomery Al | Member Since: 12/29/10 | IP: (2600:1005:b10f:c) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1200267 posted 01/31/15 08:15 AM     Remind Me!  Send Private Message   Edit Post
No problem! glad you got it. Bet it felt great once it "popped".
12yr+ Vr4 owner.
Family Guy
tsitalon1
Member +
Galant VR-4 org Post #: 1200273 posted 01/31/15 09:19 AM     Remind Me!  Send Private Message   Edit Post
Absolutely!!
Makes you wonder about the competency of the local machine shop though
I've given up on most of the machine shops in my area years ago anyway.
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1200289 posted 01/31/15 10:36 AM     Remind Me!  Send Private Message   Edit Post
So glad you got it apart. Maybe make this a sticky or somebody do a how to for future use? Also I see why most machine shops don't do stuff like this. They'll wrestle with it for an hour or more using their tools and stuff and most people get upset if they charge over $10 . That's an hour they wasted not working on something else that's paying $50 an hour or more.
715/1000
1284/2000
Galant VR-4 org Post #: 1200291 posted 01/31/15 10:40 AM     Remind Me!  Send Private Message   Edit Post
That's why you bring a box of donuts, or bagels. Food always makes techs and machinists happy.
12yr+ Vr4 owner.
Family Guy
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1200294 posted 01/31/15 10:55 AM     Remind Me!  Send Private Message   Edit Post
LOL, learned that on Jafromobile.
715/1000
1284/2000
Galant VR-4 org Post #: 1200297 posted 01/31/15 11:26 AM     Remind Me!  Send Private Message   Edit Post
I've done a lot of small stuff for a box of donuts in the past.
12yr+ Vr4 owner.
Family Guy
tsitalon1
Member +
Galant VR-4 org Post #: 1200304 posted 01/31/15 12:06 PM     Remind Me!  Send Private Message   Edit Post
Hell, we never got to the point of discussing payment, I would of paid $75 just to have them press it out, which is all I asked them to do. Idiots they are!
Posts: 309 | From: Montgomery Al | Member Since: 12/29/10 | IP: (2600:1005:b119:a) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1200305 posted 01/31/15 12:18 PM     Remind Me!  Send Private Message   Edit Post
That just goes back to a few bad apples ruin the whole bunch. There are those people out there that don't mind paying you for your time and don't expect anything for nothing. Then there are those that want you to stop what you're doing, fix their stuff and tell them to have a great day.
OP, didn't mean to sound like I was saying you wanted it done for nothing. I was just saying they may have assumed that by being burnt in the past.
715/1000
1284/2000
Galant VR-4 org Post #: 1200312 posted 01/31/15 12:57 PM     Remind Me!  Send Private Message   Edit Post
Everyone has been burned. That's why most shops operate how they have to.
12yr+ Vr4 owner.
Family Guy
tsitalon1
Member +
Galant VR-4 org Post #: 1200340 posted 01/31/15 06:23 PM     Remind Me!  Send Private Message   Edit Post
Still need an alignment and need to address some rubbing issues, but overall I'm happy with it.
Pages: 1 | 2
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.069 seconds in which 0.039 seconds were spent on a total of 14 queries. Turbo powered.
