Galant VR-4 Forums » Galant VR-4 » Technical Discussions » brake master cylinder?
turbohf
anyone even read this?
613/2000
Galant VR-4 org Post #: 1166462 posted 04/06/14 09:26 PM     Remind Me!  Send Private Message   Edit Post
so it appears that my brake master cylinder is leaking. just added fluid to it again (the second time since buying it 2 years ago) so i looked around a little. and i have a trail down the booster of oily nastiness. i shot it with brake clean and it took the paint with it, so yeah, its brake fluid.
so real question is where should i be buying one from? just try another used one? or aftermarkets ok? place we get stuff from at work sells Centric parts. like this click
thanks
Dustin
1991 GVR4 #613
1966 Chevrolet Chevy II Nova 400 4dr Sedan V8
Posts: 540 | From: Lake Stevens, WA | Member Since: 11/18/11 | IP: (184.78.169.242) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166464 posted 04/06/14 09:55 PM     Remind Me!  Send Private Message   Edit Post
This is a perfect time for the 3g master swap
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1653 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (72.128.64.46) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1166473 posted 04/06/14 10:47 PM     Remind Me!  Send Private Message   Edit Post
got more info?
i would love to upgrade the brakes, as they dont inspire confidence at all. BUT. im kinda refusing to spend any more money on her cuz she is being a bitch. has a new/built motor with new everything, but doesnt behave right, and refuses to run on anything but stock ECU/MAFT... so thats all on hold until my buddy can help me trouble shoot the car/AEM EMS. and i have moved onto putting motor/money into my Integra as the previous owner put the the most torqueless motor on the planet in it...
Dustin
1991 GVR4 #613
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1166496 posted 04/07/14 07:50 AM     Remind Me!  Send Private Message   Edit Post
I have a few used 3g M/C's, I'd let one go for $32 shipped. These have the slightly larger 1-1/16" bore.
93 Mitsubishi Expo LRV
95 Eagle Summit DL coupe
98 Mitsubishi Mirage DE coupe
Posts: 2502 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (184.3.235.224) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166500 posted 04/07/14 08:21 AM     Remind Me!  Send Private Message   Edit Post
Quoting turbohf:
got more info?
Basically you get one from a 3g eclipse, get some adapter fitting that go from bubble metric to your standard excisting fittings. Or you can reflare the lines and just put bubble ends on them, you do have to fanese the lines a bit because the port are in different locations, but that no big deal. Also if you havent removed your ABS already please do so.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Posts: 1653 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.82) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1166504 posted 04/07/14 08:40 AM     Remind Me!  Send Private Message   Edit Post
There was recent thread on the 3G master swap. I highly highly highly recommend it. With the stock brakes it was night and day. Pedal feel was way better. It's not a huge upgrade, but allows more fluid pressure with less pedal movement, which will give you more confidence.
Also once I went with the bigger outlander rotors, the swap made an even bigger difference. I can have my passengers eat dash easily now. Still have the abs, but de-activated.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
turbohf
613/2000
Galant VR-4 org Post #: 1166538 posted 04/07/14 11:55 AM     Remind Me!  Send Private Message   Edit Post
like that?
I can't find the specs on the thread pitch for either cylinder.
also looks like a couple people are just railing them in without an adapter without issue? im sure I'll have issue both ways...
Dustin
1991 GVR4 #613
Posts: 540 | From: Lake Stevens, WA | Member Since: 11/18/11 | IP: (172.56.33.25) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166539 posted 04/07/14 12:07 PM     Remind Me!  Send Private Message   Edit Post
Yeah like those, but you need the end to be bubble flare, napa should have them.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
turbohf
613/2000
Galant VR-4 org Post #: 1166540 posted 04/07/14 12:08 PM     Remind Me!  Send Private Message   Edit Post
what threads?
Dustin
1991 GVR4 #613
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166542 posted 04/07/14 12:15 PM     Remind Me!  Send Private Message   Edit Post
I used this part# 641-5026, m10x1.0 male with a female 3/8x24.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1166543 posted 04/07/14 12:24 PM     Remind Me!  Send Private Message   Edit Post
^That the NAPA part #?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3436 | From: SoCal | Member Since: 01/02/12 | IP:
(174.236.228.29) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166546 posted 04/07/14 12:35 PM     Remind Me!  Send Private Message   Edit Post
For the adapter yea.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
turbohf
613/2000
Galant VR-4 org Post #: 1166563 posted 04/07/14 03:20 PM     Remind Me!  Send Private Message   Edit Post
that work?
Dustin
1991 GVR4 #613
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166564 posted 04/07/14 03:26 PM     Remind Me!  Send Private Message   Edit Post
Yep
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Galant VR-4 org Post #: 1166565 posted 04/07/14 03:31 PM     Remind Me!  Send Private Message   Edit Post
Quoting MellowVR4:
Why would you want to use a 3/8 thread for the female side when the vehicle uses 10x1.0? Both sides should be 10 x 1.0 thread.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10840 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166567 posted 04/07/14 03:42 PM     Remind Me!  Send Private Message   Edit Post
They dont sell one that is metric on both side, That's why I used that part#.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
715/1000
1284/2000
Galant VR-4 org Post #: 1166574 posted 04/07/14 04:21 PM     Remind Me!  Send Private Message   Edit Post
and people gave me grief over just threading the factory line into the 3g. now your recommending cross threading metric to sae?
12yr+ Vr4 owner.
Family Guy
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166610 posted 04/07/14 07:48 PM     Remind Me!  Send Private Message   Edit Post
Nooo, I put sae fitting on the lines and adapted that to the adapter!
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Galant VR-4 org Post #: 1166612 posted 04/07/14 08:05 PM     Remind Me!  Send Private Message   Edit Post
Perhaps that is pertinent information to provide when giving someone advice to use that fitting?
I'm sure someone sells a bubble/double flare adapter in the same thread. Autozone likely has them, but most workers there have no idea how to actually deal with brake line work. They have about 30 different brake fitting adapters they sell, including short lines. You have to ask them to go look at it for yourself if you know what you are doing.
Posts: 10840 | From: Michigan | Member Since: 03/05/01 | IP: (76.226.199.154) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1166613 posted 04/07/14 08:19 PM     Remind Me!  Send Private Message   Edit Post
so back to the beginning...
i havent found a 10x1.0mm inverted to 10x1.0mm bubble fitting in my searching yet either. sounds simple enough...
Dustin
1991 GVR4 #613
715/1000
1284/2000
Galant VR-4 org Post #: 1166665 posted 04/08/14 08:11 AM     Remind Me!  Send Private Message   Edit Post
So cut the line and installed and new fitting? I'm not following what you did.
12yr+ Vr4 owner.
Family Guy
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166674 posted 04/08/14 09:42 AM     Remind Me!  Send Private Message   Edit Post
Since I couldn't find an adapter that was Both metric bubble male with a metric inverted female. All I found was a fitting that had a SAE 3/8x24 pitch inverted female and obviously with a metric bubble male, so I just cut the flare that was already on the line and I put SAE fitting inplace so I can use the fitting.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Posts: 1653 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.74) | Report this post to a Moderator
Galant VR-4 org Post #: 1166682 posted 04/08/14 10:14 AM     Remind Me!  Send Private Message   Edit Post
Didn't think that would be a rare piece, but apparently it is. Here is one.
fitting
715/1000
1284/2000
Galant VR-4 org Post #: 1166697 posted 04/08/14 11:18 AM     Remind Me!  Send Private Message   Edit Post
Quoting MellowVR4:
So if you cut the line, why not just put the proper fitting in place instead?
12yr+ Vr4 owner.
Family Guy
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1166706 posted 04/08/14 12:00 PM     Remind Me!  Send Private Message   Edit Post
I don't have a bubble flaring tool, All I had at the time was the inverted kit.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Posts: 1653 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.72) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.079 seconds in which 0.045 seconds were spent on a total of 14 queries. Turbo powered.
