Galant VR-4 Forums » Galant VR-4 » Technical Discussions » KOYO radiator options
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1154292 posted 01/03/14 03:02 PM     Remind Me!  Send Private Message   Edit Post
I was looking up some info on different radiators for different vehicles and their are some viable options for "almost" 100% bolt in. Can probably make spacers for the bottom vr4 mounts or custom brackets up top.
Stock vr4 radiator dimensions:
Width = 26-5/16"
Height = 14-13/16"
Stock 1g dsm radiator dimensions:
W = 26-5/16"
H = 13-7/8"
Option # 1
Koyo 36mm V-core for 1g dsm (stock fitting all aluminum racing)
W = 660mm (26-5/16")
H = 350mm (14")
Option # 2
Koyo 53mm R-core for 2g dsm
W = 682mm (27.28")
H = 350mm (14")
Option # 3
Koyo 53mm R-core for evo 1-3
W = 654mm (26.16")
H = 375mm (15")
Option # 4
Koyo half size racing radiator for evo 8/ 9
W = 342mm (13.68")
H = 375mm (15")
I know a few guys here have played around with some of these options in the past.
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (173.245.55.89) | Report this post to a Moderator
Street Surgeon
Professor Street Surgeon
501/1000
Galant VR-4 org Post #: 1154330 posted 01/03/14 08:46 PM     Remind Me!  Send Private Message   Edit Post
I have the Evo 3 installed in my Galant, the specs listed on their website are pretty accurate but don't paint the whole picture.
These are the measurements I took with my mic when I put it in.
OEM Radiator:
End Tank top/bottom: 55mm
Core: 34mm
Koyo Evo III Radiator:
End Tank top/bottom: 61mm
Core: 53mm
The 61mm end tanks on the top and bottom are pretty big and will require a fabricator with a deft touch to get piping to go the stock/ets route for a front mount. Also, as mentioned before it does sit an inch lower than a stocker so you'll either need spacers at the bottom or not mind it sitting a hair lower than stock.
Cory O.
'92 Mitsubishi Galant VR-4 501/1000
Heavily modified, barely driven, some assembly required.
Posts: 941 | From: Omaha, Nebraska | Member Since: 03/03/04 | IP: (108.162.221.130) | Report this post to a Moderator
SSGdave
1855/2000
Galant VR-4 org Post #: 1154343 posted 01/04/14 12:17 AM     Remind Me!  Send Private Message   Edit Post
I have an Evo3 Aftermarket Aluminum Radiator in 1855.
It fits very well, I only needed to shim the bottom mounts using spare piece of silicone hose that was around 1/4 inch tall (can't recall exact measurement). To get the top Galant mounts to "hold" the Radiator correctly.
As far as the OEM fans bolting up, I didnít use the OEM fans so I donít now if they mount up correctly. I did a slim puller and pusher set up in the OEM configuration.
Yeah its me "SGTdave". ...and I still don't fuck around when there's work to be done.
1991 GVR4 1855/2000 - Daly Driver "Frankie"
1990 GGSX(turbo)- Project/Serious Road Race Car "Uncle Randy"
Posts: 137 | From: San Diego, CA | Member Since: 05/31/11 | IP: (108.162.254.99) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1155514 posted 01/11/14 11:00 PM     Remind Me!  Send Private Message   Edit Post
How do we correlate these radiators into the part numbers found on Ebay?
G, you gave me the part #C0233, but it is no longer available on ebay.
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (67.168.143.160) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1155552 posted 01/12/14 10:13 AM     Remind Me!  Send Private Message   Edit Post
When I did a search for possible radiators to cross over into the C53A (Turbo Mirage/Colt), I came out finding that the Galant/GVR4 rad was a drop in with two minor differences:
Upper rad hose was pushed over 1-2 inches, and the overflow outlet was aimed directly at the LH headlight versus RH/RH strut area. Minor workaround, but otherwise identical in all respects.
My point above the fact that there are literally next to no rads left in North America (according to 1800Radiator whom I was sourcing through while I stood at their counter) for a C53A or E30/E39A platform) due to low call volume and sadly only one radiator was found in a back corner of a warehouse, from some company like Samsung (or some near derivative), IS that the part number I used was a CU233 (Galant) or CU234/CU235 serperceded for the Colt. Alternative numbers maybe 234/235KO or 233KO.
Here's my comparison thread:
It's a bit of a read through, but great info if you are in a pinch for what to use. I did some research on what was available at the click of a button, versus custom built or shipping from way off overseas. I could find parts overseas, but it would double/triple the cost to bring it here.
C53A 1 of the ~1500
Edited by FlyingEagle (01/12/14 10:16 AM)
Posts: 1631 | From: THE Ottawa | Member Since: 03/05/05 | IP: (173.34.10.166) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1155564 posted 01/12/14 12:09 PM     Remind Me!  Send Private Message   Edit Post
Call koyo and ask them who has that part # in stock. Simple.
Quoting coyotes:
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (98.144.117.58) | Report this post to a Moderator
Galant VR-4 org Post #: 1155565 posted 01/12/14 12:45 PM     Remind Me!  Send Private Message   Edit Post
I have a DSM rad and the top is low like everyone states but the bottom connector is a little too close to the lower cross member for my likeing. It should ideally be angled up some. Just throwing that out there.
Edit: Actually after closer inspection the bottom port should be about 2 inches toward the driver side. to where this nice groove is.
Edited by tektic (01/12/14 09:22 PM)
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1155574 posted 01/12/14 02:28 PM     Remind Me!  Send Private Message   Edit Post
G,
I found another one on Ebay. That is a direct replacement or does it need to be shimmed? I am going to buy as soon as I have your answer. Thanks
1226/2000
JDM Unit
486/1000
Galant VR-4 org Post #: 1155595 posted 01/12/14 05:52 PM     Remind Me!  Send Private Message   Edit Post
Direct replacement.
www.nostalgic.co.jp
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1155596 posted 01/12/14 06:03 PM     Remind Me!  Send Private Message   Edit Post
Purchased. :]
Thanks for your patience of my endless dumb questions G.
1226/2000
Paddy1337
464/1000
Galant VR-4 org Post #: 1155648 posted 01/13/14 11:23 AM     Remind Me!  Send Private Message   Edit Post
is it all that much more expensive to get a core and have it welded locally? I honestly don't know, because my welding is done on the hook-up, but for a perfect fit to your exact car setup it sounds pretty beneficial.
I will say, I've seen some Koyo's sell pretty darn cheap in general, so maybe it is a lot more money...
Posts: 43 | From: PA/NC | Member Since: 11/01/13 | IP: (98.121.138.176) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1155650 posted 01/13/14 11:25 AM     Remind Me!  Send Private Message   Edit Post
anyone know where to get the rubber mounts? Mine need replacing and haven't found them in parts stores locally.
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (172.56.32.21) | Report this post to a Moderator
RayH
561/1000
Galant VR-4 org Post #: 1155658 posted 01/13/14 12:32 PM     Remind Me!  Send Private Message   Edit Post
When I replaced the radiator in my 94 Expo it looked like it could be a real close replacement for the Galant.
Posts: 2701 | From: NJ | Member Since: 04/09/01 | IP: (209.222.18.75) | Report this post to a Moderator
Street Surgeon
501/1000
Galant VR-4 org Post #: 1155689 posted 01/13/14 02:56 PM     Remind Me!  Send Private Message   Edit Post
Quoting coyotes:
Mitsubishi, or other online vendors.
Cory O.
Posts: 941 | From: Omaha, Nebraska | Member Since: 03/03/04 | IP: (132.3.49.78) | Report this post to a Moderator
Galant VR-4 org Post #: 1155725 posted 01/13/14 05:48 PM     Remind Me!  Send Private Message   Edit Post
Quoting coyotes:
Upper or lower? I have a few spare lowers.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10838 | From: Michigan | Member Since: 03/05/01 | IP: (68.248.74.249) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1155910 posted 01/15/14 08:28 AM     Remind Me!  Send Private Message   Edit Post
When my lower mounts were separating from there outward portions, I used RTV to seal things back up. GREY. Worked a charm and was likely stronger than the original rubber was.
If nothing else is available, guys have posted about using the rubber bushings from stabilizer/sway bar links. Most have the correct center hole (or close), and can be modded to fit or will slide right into the hole where the original rubber was located. Can always be RTV'd back in.
C53A 1 of the ~1500
vr4play
handles best on 3 tires
816/1000
Galant VR-4 org Post #: 1155932 posted 01/15/14 10:58 AM     Remind Me!  Send Private Message   Edit Post
Has anyone tried to see if the evo mounts will fit our cars. They look like it could be a possibility but the angle may be wrong.
816 of 1000
[email protected]
??? of 2000
[email protected] on 93oct
[email protected] on C16
[email protected] on E90
ASE Certified Master Technician
www.Performance-Alignment.com
Posts: 397 | From: Cincinnati, Ohio | Member Since: 02/07/08 | IP: (74.215.234.86) | Report this post to a Moderator
MuffinMan7580
570/1000
Galant VR-4 org Post #: 1209222 posted 05/31/15 01:18 AM     Remind Me!  Send Private Message   Edit Post
Bringing it back from the dead, but I ordered a Koyo EVO 3 radiator for 570. I'm fine with it being a little shorter than stock, but I am not alright with it not having a bung for the fan switch! I will see if the part number was on the box and post that as well, but if anyone else has the KOYO, will you chime in if yours has a bung for a fan switch or not?
Edit-Apparently their are 2 part numbers R/HH030561. The "R" model is a 53mm core while "HH" is a 48mm core. I'll measure mine and update which is which.
'92 GVR4 #570/1000
Edited by MuffinMan7580 (05/31/15 01:31 AM)
Posts: 142 | From: Fort Bragg, NC | Member Since: 08/06/11 | IP: (65.191.189.185) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1209233 posted 05/31/15 10:42 AM     Remind Me!  Send Private Message   Edit Post
Buy an inline bung and add it to your lower rad hose.
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
MuffinMan7580
570/1000
Galant VR-4 org Post #: 1209259 posted 05/31/15 05:59 PM     Remind Me!  Send Private Message   Edit Post
For M16x1.5? Almost everything I've found is NPT thread. If I do that, I'd still have to drill and tap it, on top of buying the inline housing.
Edited by MuffinMan7580 (05/31/15 06:00 PM)
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1209272 posted 06/01/15 12:08 AM     Remind Me!  Send Private Message   Edit Post
The HH cores are new and are replacing the R's. supposedly cools just as good and slimmer.
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 800 | From: Corona, CA | Member Since: 04/08/08 | IP: (2605:e000:a447:c) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1209273 posted 06/01/15 12:22 AM     Remind Me!  Send Private Message   Edit Post
I don't remember the thread but the factory sensor works on the greddy bung.
www.nostalgic.co.jp
MuffinMan7580
570/1000
Galant VR-4 org Post #: 1209285 posted 06/01/15 09:43 AM     Remind Me!  Send Private Message   Edit Post
I'm tracking the change in cores. Does anyone else have an EVO 1-3 radiator that can chime in about the bung for the fan switch?
'92 GVR4 #570/1000
Posts: 142 | From: Fort Bragg, NC | Member Since: 08/06/11 | IP: (143.85.76.18) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1209312 posted 06/01/15 02:55 PM     Remind Me!  Send Private Message   Edit Post
I have a Tuners Nation radiator which essentially is an Evo 1-3 radiator and they added a bung in the same location as the AEM unit.
92 GVR4 #802 link
SOLD: 92 GVR4 #611
Posts: 800 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Dasith
I've never been to usa, but prostitution is probably legal there i think.
Galant VR-4 org Post #: 1209338 posted 06/01/15 08:11 PM     Remind Me!  Send Private Message   Edit Post
i have an Evo 3 radiator and it doesn't have a bung
E33A - Sold
E39A Jspec - Getting Built
Posts: 98 | From: Melbourne, Australia | Member Since: 03/18/10 | IP: (202.76.173.206) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.088 seconds in which 0.051 seconds were spent on a total of 14 queries. Turbo powered.
